akirby Posted October 26, 2019 Report Share Posted October 26, 2019 I think they did away with the option to set a custom interval many years ago. Had it on my 06 Fusion but not the later vehicles, 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted October 26, 2019 Report Share Posted October 26, 2019 I'm in the same boat with Ron, that option is not available on my 17' Sport. ? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 26, 2019 Report Share Posted October 26, 2019 (edited) this is for gen 1.5, so gen 2 might be different. info grabbed from the owner manual. 2015 type 1 and 2 display: settings > vehicle > oil life reset 2016, 2017, 2018 type 2 display only: settings > vehicle > oil life reset Edited October 26, 2019 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 26, 2019 Report Share Posted October 26, 2019 8 hours ago, onyxbfly said: I'm in the same boat with Ron, that option is not available on my 17' Sport. ? Looks like we didn't pay attention to the section this is posted in "2007-2014 Edge & MKX Generation I ". 1 Quote Link to comment Share on other sites More sharing options...
rsucre Posted November 19, 2019 Report Share Posted November 19, 2019 Hi. I have to replace the oil pressure sensor on my Ford Edge 2013 SEL (3.5 V6). is there a guide, instructions or pictures of the process? Disassembling the front and removing the fan is the only way to get there? thanks!! Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted November 20, 2019 Report Share Posted November 20, 2019 Just did mine at the shop. I looked at the position and decided I didn't want the bruises needed to get access. It's about an hours labor. It also went in for a coolant flush and other assorted goodies so I figured why not piggyback everything. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 21, 2019 Report Share Posted November 21, 2019 How to replace the EOP switch 1 Quote Link to comment Share on other sites More sharing options...
nickgiza Posted August 24 Report Share Posted August 24 I just changed the oil pressure sensor and since then it has been leaking out oil very fast as soon as you start it, I thought it could be the oil filter housing so I changed that and still have a oil leak. Wha could this oil leak be coming from and how can I fix it? Or is my ford edge junk? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 24 Report Share Posted August 24 1 hour ago, nickgiza said: I just changed the oil pressure sensor and since then it has been leaking out oil very fast as soon as you start it, I thought it could be the oil filter housing so I changed that and still have a oil leak. Wha could this oil leak be coming from and how can I fix it? Or is my ford edge junk? Wouldn't you suspect the replacement oil pressure sensor? 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted August 24 Report Share Posted August 24 7 hours ago, 1004ron said: Wouldn't you suspect the replacement oil pressure sensor? logic is your friend 1 Quote Link to comment Share on other sites More sharing options...
