Gen 2 Rear Motor Mount Question
  On 4/27/2018 at 10:16 PM, onyxbfly said:
I did not realize that there was a initial thread for the CP-e motor mount.
If I did I would have linked to it.
For the laymen among us I.E me what does N.V.H mean?
Thanks in advance!
Not a problem onyxbfly!
Noise, vibration, and harshness (NVH), also known as noise and vibration (N&V), is the study and modification of the noise and vibration characteristics of vehicles, particularly cars and trucks.
Hopefully that helps... :hat_tip:
Thanks!
I just got my car back from GAS and one of the first things I noticed was more NVH in the cabin at idle. I had the CP_e 60 Duro RMM installed and although it is not bad it is noticeable. It does take away from the Edge Sport's super quit luxury cabin at idle. Don't get me wrong it is not that bad the moment you accelerate off idle it goes away. If you are not experiencing wheel hop then you don't need this part. If you have experienced wheel hop then the CP_e 60 Duro RMM is the way to go. It will cut your times and save driveline parts from damaging shock loads.
