Will 2017 Rims fit a 2011?
sigmamason
Not necessarily unsafe if installed correctly but can be hard on wheel bearings as the angle of thrust is moved away from the design. Further, most certainly has a detrimental effect on handling as hanging a big weight further out messes a lot with the suspension design. And there's the added weight of the adapters. At a minimum you need adjustable rebound and dampening to compensate but that will reduce the effect, not eliminate or improve. All these factors also relate to the bigger rim trend: metal weighs a lot more than rubber and air. Going from a 21" to 22" rim has measurable effect, going from an 18" to a 24" is nuts if you care about performance and drivability. Race cars of all varieties have small rims and big rubber (sidewalls). There is a reason for this...
