Ghhuff Posted April 8, 2018 Report Share Posted April 8, 2018 (edited) I have a 2017 Edge Titanium that came with Halogen headlamps, but I bought OEM (factory) HID headlamps off of Ebay to use. I need to find a mod (possibly FORScan) to tell the BCM that the car is equipped with HIDs. My dealer checked with Ford, but was told I could not change. Does anyone know if this is correct or not? Thanks Edited April 18, 2018 by Ghhuff Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted April 8, 2018 Report Share Posted April 8, 2018 (edited) sadly, your in an uphill battle. Would have been probably cheaper to retrofit the lights, and you would have had better lighting. I'm curious, how much you paid for OEM HID lights off ebay, hopefully no broken tabs too. I'm looking for a set to cut open and modify to my liking.your post would be better suited on hidplanet.comand headlight junkies on facebook Edited April 8, 2018 by Nick Halstead Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 8, 2018 Author Report Share Posted April 8, 2018 I looked carefully for almost a year, and got lucky. I found a ford dealer that wanted to unload excess parts, got the left for $525. And a dealer liquidation for $500 for the right side. Both were brand new and I got the ballasts for about $30 on eBay. Much more economical than the usual dealer cost of $1000 to $1500 each side. Im currently using the oem lights with a capacitor and relay and they work fine, for headlights, but I have non functional DRLs on the HID units. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted April 8, 2018 Report Share Posted April 8, 2018 you got the wireless ballasts for $30. each? that's crazy! But for half of what you paid you could have bought some HID projectors, awesome bulbs and cut open and retrofitted your original lights and would have 100% better lighting than fords shitty oem HID 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 8, 2018 Report Share Posted April 8, 2018 From the 2015+ F150 sheet, there is a line in the BCM that sets the type of headlight, (don't know if it helps): 726-25-02 xxx* xxxx xxxx Headlamp Style Cfg: 0=BI_FUNC Halogen, 1=BI_FUNC HID, 2=Dual, 3=Quad Ā Also, better check if the wiring is the same. I remember a person did something similar to a 2010 Taurus Limited where he installed OEM HID headlights from a Taurus SHO, but at the time he had to make some wiring changes (found the thread). Ā Also, if the wiring is correct (or corrected), you'll need to change the DRL to enable the stock OEM DRL of the new headlights because on HID headlight they are "dedicated" DRL versus "High beam" on the Halogen setup. Ā From the 2G Fusion sheet: 726-45-01 (2014+ MY) xxxx XXxx xxxx (Note: This setting enables all choices in the list for DRL options) (BdyCM) Set value at XX to 7F 726-50-01 (2014+ MY) XXxx (BdyCM) 01 (Disabled - Default (USA) / No DRL) 02 (Enabled - DRL Low Beams) 04 (Enabled - DRL Front Fog Lamps) 08 (Enabled - DRL Front Turn Lamps) 10 (Enabled - DRL Dedicated) - Enables BCM DRL Outputs - C2280C Pins 36 (Right) and 40 (Left) 20 (Enabled - DRL High Beams) 40 (Enabled - DRL Low Beams and Dedicated) Ā 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 8, 2018 Author Report Share Posted April 8, 2018 Thanks omar302! Yes the wiring is the same. I have the wiring manual. I had the dealer check and they found a parameter for DRLs, but none for HIDs. The dlr parameter I s only (permanent on or off), which I can already select on my dashboard menu. If anyone can find an exact parameter for HIDs in the Edge, that would be most helpful, as I suspect it also sets the drls to function, with this type of headlight assembly. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 8, 2018 Report Share Posted April 8, 2018 As I stated in my previous post, the As Built Data is what sets which bulbs act as DRL. My Edge Sport with HID has "10" which means dedicated DRL. 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 8, 2018 Author Report Share Posted April 8, 2018 I saw it said fusion data, but if its the same in Edge, then thanks! Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 8, 2018 Report Share Posted April 8, 2018 The 2013+ Fusion is very similar to the 2015+ Edge in this regard. Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 8, 2018 Author Report Share Posted April 8, 2018 My as built data shows: 726-50-01 0280, which if your chart is right it shows DRL on low beams, which would be as it seems to act. Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 18, 2018 Author Report Share Posted April 18, 2018 Ā Hi Omar302, after chasing 2 Ford dealers to enable my DRLs (I offered to pay) and being refused, I decided to order an OHP ELM327 and will use Forscan to try it myself. Hopefully Ill get a chance to try it this coming weekend. Let me know if you have any tricks or words of wisdom for me. Ill report back in this thread of my results. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 18, 2018 Report Share Posted April 18, 2018 Just remember to back up your settings in case you wanted to revert the settings. Also, like some members have already done, you can make an excel sheet with the changes you want so that it'll be easier to look for the changes you want to make. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 19, 2018 Report Share Posted April 19, 2018 Hi Omar302, after chasing 2 Ford dealers to enable my DRLs (I offered to pay) and being refused, I decided to order an OHP ELM327 and will use Forscan to try it myself. Hopefully Ill get a chance to try it this coming weekend. Let me know if you have any tricks or words of wisdom for me. Ill report back in this thread of my results.Can't you turn your DRL's on and off from the info panel? Settings->> Vehicle->> lighting->> DRL (on/off) 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 19, 2018 Report Share Posted April 19, 2018 That is a very good point enigma-2! OP should check for that first. Also, note that for the DRL to work in that case, the headlight switch needs to be in "Auto" & transmission out of "P". Link to owners manual. 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 19, 2018 Author Report Share Posted April 19, 2018 Yes I can turn on from the info panel.. but let me explain further. I need to enable the DRLs in the BCM to work with the separate DRL bulbs in the OEM HID headlight assemblies that I installed to upgrade and replace the original Halogen assemblies that came with the car. Currently, the DRL config in the BCM thinks I have Halogens and uses the same bulb for DRLs as the headlights at a reduced intensity. So Ill change the parameter for discreet DRLs...instead of combined. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 19, 2018 Report Share Posted April 19, 2018 Ghhuff, your right. I got confused & forget what you had explained in your original post. Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 20, 2018 Report Share Posted April 20, 2018 Here are the as built values from a Canadian Sport Edge with DRL enabled by default from Factory. Make note that for Canadian Edge the DRL menu in the left IPC is not available Ā IPC 720-02-01 69A4 2C50 1ED1 BCM 726-16-02 0202 0202 024F BCM 726-21-01 1401 0001 0267 BCM 726-45-01 0A00 1100 018F BCM 726-50-01 108E 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 20, 2018 Author Report Share Posted April 20, 2018 Thanks ONEDGE16. I just tried to write 108E for 726-50-01, and get writing blocks failed-incompatible configuration. And it goes back to 0280. So something is not happy trying this. I may try changing 726-45-01 to your config and then 726-50-01 and see how that goes tomorrow. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 20, 2018 Report Share Posted April 20, 2018 Try changing this: Ā 726-45-01 (2014+ MY) xxxx XXxx xxxx (Note: This setting enables all choices in the list for DRL options), the XX to 7F 1 Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 20, 2018 Report Share Posted April 20, 2018 you have to change 726-45-01 block as indicated by omar302, then you can change the 726-50-01 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 20, 2018 Author Report Share Posted April 20, 2018 Yes I can change to 7F, but 2 questions. What do I use for the checksum? Calculate it myself? And, onedge16s block 726-45-01 is NOT set at 7F, and if I set it that way, do I set it back after I change the parameter in 726-50-01?? Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 20, 2018 Report Share Posted April 20, 2018 Ignore the checksum error, it will correct itself (I'm not sure if it's done by ForScan or the module). Ā As for 7F, my understanding is that your BCM is programmed with a certain fog light setting (low beams in your case) and the BCM would not allow you to change (the error you're getting), by setting the "7F" it is like your telling the BCM to accept other fog light settings, then you can change it. Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 20, 2018 Author Report Share Posted April 20, 2018 Thanks after I change it to 7F, and then change the lights type... then do I leave 7F there or change it to something else? Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 20, 2018 Report Share Posted April 20, 2018 Leave 7F. Do not change it to anything else Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 20, 2018 Author Report Share Posted April 20, 2018 Alright!!! I got the DRLs working properly and the drl switchback with turn signal set. It works great and just like it came that way from the factory. Thanks for your help ONEDGE16 and omar302! 2 Quote Link to comment Share on other sites More sharing options...
