RDS on the instrument panel right screen?
I don't get RDS (Radio Data System) information on the instrument cluster's right screen. RDS only shows on the 8" center display.
Is that normal or do US Edges get RDS in the instrument cluster like the older Gen1.5?
Edited by omar302
RBDS is the American superset of the more generic RDS system. The RBDS standard encompasses the features of RDS and adds some extra things (e.g. provisions for the emergency broadcast system and use on the AM band) along with some differences in encoding such as some different PTY (program type) classifications.
  • Like 3
  • 9 months later...
Living far from a city is why you haven't seen any HD Radio stations - they're all or nothing.  HD Radio is a digital broadcast so there's no fading or hiss like traditional FM when you are at the edge of the reception area... it will simply cut out altogether when the signal becomes too weak to process.
HD Radio does allow additional metadata to be broadcast compared to RDS.  It is not uncommon to have album art along with artist, title and track information displayed when listening to an HD Radio broadcast.
BTW, the HD in HD Radio doesn't mean High Definition as one would expect.  It's simply a brand name and there is no improvement in sound quality other than the fact being digital reduces background noise.  The bandwidth available for the digital signal could have been used to broadcast higher quality sound but North American broadcasters chose to use the extra bandwidth to provide additional channels instead.  So you're really not really missing much.
HD Radio is not commonly used outside North America.  The similar DAB and DAB+ systems are used in most of Europe and a few other countries around the world.
  • Like 3
  • 1 year later...
On 1/23/2019 at 9:05 PM, omar302 said:
Maybe then my IPC needs updated software!
Hi,
have you got it working?
Mine 2018 Edge was showing RDS there up until some point and then, well it doesnt work anymore! I dont know what was it related to , either to SYNC 3 update, which is unlikely or maybe to some Forscan mods I've done...
15 minutes ago, redden18 said:
Hi,
No. Didn't get it yet. I think I need to update the Firmware on my IPC as it seems 2017/2018 models are different. Try to "Master Reset" the Sync3 and see if it helps. Does the RDS info still show in Sync3? if not, maybe it is turned off in the radio settings. (Sync2 does have a RDS On/Off setting, not sure of Sync3).
RDS is on in the settings and it does display info on the main unit, but not on IPC screen. I know its working for sure, because mine '12 Explorer with SYNC 2 displays RDS just fine on right IPC screen.
Edited by redden18
Sorry, can't help. Although on my previous 2011 MKX, RDS did not work (on IPC & main display) when the ACM ABD was set to my region to show all radio frequencies. Setting ACM tuner region to US would make RDS show on both screens but would lose even frequencies. With the 2016 Edge the ACM tuner region doesn't affect RDS.
On the other hand, I did notice in some pictures that 2017+ models show distance to Empty in the yellow box low fuel warning (as did my 2011), but my 2016 doesn't. Hence I was convinced the firmware is different.
What ForScan have you done recently? Maybe it did have an effect.
Edited by omar302
I've enabled Nav-in-motion changing region to 5753, I'll do some testing changing it back to Canada's and report it back.
My 12 Explorer with SYNC 2 has nav-in-motion enabled and yet RDS is there. SYNC 2 and SYNC 3 are different beasts though.
Changed region back to Canada, 4341. Performed hard reset - nothing. I'll leave it for a while to see if anything changes after multiple restarts.
Here is my strategies:
APIM - Accessory Protocol Interface Module
Part number: JR3T-14G371-CED (latest known: JR3T-14G371-CJD)
Strategy : HB5T-14G374-CA
Calibration: HB5T-14G375-CA
ACM - Audio Control Module
Part number: FT4T-19C107-HE (latest known: FT4T-19C107-HF)
Strategy : FT4T-14D099-HE
Calibration: FT4T-14D100-HB
IPC - Instrument Panel Control Module
Part number: GT4T-10849-DC
Strategy : GT4T-14C026-CB
Calibration: GT4T-14C088-CB
Please do update what happens. These are my numbers, though mine is a 2016 and with Sync2 (MyFord Touch). I noticed the IPC strategy & calibration are the same as yours, shouldn't this mean they have the same firmware/software? When you get the low fuel yellow box warning, do you also get the DTE in the box? Mine doesn't though I noticed newer models do.
Bus: HSCAN
Part number: ES7T-14D212-FA (latest known: ES7T-14D212-FA)
Strategy : EM5T-14D205-AD
Bus: HSCAN3
Part number: FT4T-19C107-JD (latest known: FT4T-19C107-JF)
Strategy : FT4T-14D099-JD
Calibration: FT4T-14D100-JA
Bus: HSCAN3
Part number: GT4T-10849-DB (latest known: GT4T-10849-DC)
Bus: HSCAN
Bus: HSCAN3
Bus: HSCAN3
I tested with changed region - no effect, still no RDS on IPC. Mine shows DTE in the box along with telltale.
More likely, we have identical ACM and IPC, but firmware might be slightly different
