Inno Posted April 6, 2018 Report Share Posted April 6, 2018 Have anyone ever replaced his evaporator? Does anyone have evaporator replacement video? I googled but cannot find. Someone can confirm if the evaporator temperature sensor is integrated to the evaporator and cannot be replaced alone? That if the evaporator temperature sensor is faulty, the whole evaporator must be replaced? It's a 2011 Ford Edge. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 8, 2018 Report Share Posted April 8, 2018 It is in the dash thus why no video. Not one wants to remove the dash to make the video and most pay the garage to do this job as it is very time consuming and if not done correctly it results in a ton of extra work. 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 8, 2018 Report Share Posted April 8, 2018 Here's a Youtube video on how to replace the sensor in a Lincoln Zephyr (simular aren't they??) Anyway, as Mac stated, you have to pull the instrument cluster to get to it. 2 Quote Link to comment Share on other sites More sharing options...
Inno Posted April 8, 2018 Author Report Share Posted April 8, 2018 Thanks to all. In fact I need the video to help the garage as we don't have a qualified one here. I have already ordered the evaporator front US and am checking out how to replace it because I will be watching how the garage will operate. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 9, 2018 Report Share Posted April 9, 2018 Didn't know we had an evap temp sensor in the Edge/MKX. Fusion, yes ... But they also do not have the evap drain line. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted April 9, 2018 Report Share Posted April 9, 2018 On 4/9/2018 at 10:14 AM, WWWPerfA_ZN0W said: Didn't know we had an evap temp sensor in the Edge/MKX. Fusion, yes ... But they also do not have the evap drain line. No evap drain line? Say what? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 9, 2018 Report Share Posted April 9, 2018 no evap drain line on the fusion. at least for 2010-12 MYs. IDK if they started putting one in later on. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 9, 2018 Report Share Posted April 9, 2018 On 4/9/2018 at 2:04 PM, WWWPerfA_ZN0W said: no evap drain line on the fusion. at least for 2010-12 MYs. IDK if they started putting one in later on. Where does the condensation go? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 9, 2018 Report Share Posted April 9, 2018 Not sure, I will have to look at the manual for details but the idea is to shut off the system before condensation becomes an issue IIRC. Take a break periodically if you will. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 9, 2018 Report Share Posted April 9, 2018 I don’t see how that’s possible. Must be some other design. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 9, 2018 Report Share Posted April 9, 2018 ok. 1 Quote Link to comment Share on other sites More sharing options...
Inno Posted April 12, 2018 Author Report Share Posted April 12, 2018 I have been said to change the whole system as the sensor is not sold separately. Here is the part number CT4Z-19B555-K from Ford representative but actually it is a kit. Very hard to find. 1 Quote Link to comment Share on other sites More sharing options...
IWRBB Posted April 12, 2018 Report Share Posted April 12, 2018 2010-2012 Fusions have A/C condensate drains. They are on the firewall. There's no way a car could have a functioning A/C system without one. 1 Quote Link to comment Share on other sites More sharing options...
Inno Posted April 13, 2018 Author Report Share Posted April 13, 2018 Does anyone knows about the evaporator temperature sensor fault on 2011 Ford Edge Limited? How can I correct this faulty error code? Quote Link to comment Share on other sites More sharing options...
