07 Edge Dashboard
Hello, Have an 07 Edge that I want to mount a backup camera on the dash.
The small tary on top of the CD Radio has two screws underneath
Do these two screws do anything critical if used for a mount ?
Dont want to remove them if it drops something inside ?
Any input ?
I'm not certain as what the screws are for, but when you pull the plastic bezel the front part that surrounds the radio and top.part that contains the tray are all one piece and come off without tools. Easy way to check is to pull the plastic shroud (as if your replacing the radio) and see what the screws are for.
Most everyone else uses a windshield mount. (Keep it near the mirror and you can use a MirrorTap harness to power the camera - turns on and off with the radio).
