Rear Emblem Remove/Replace Question
chefduane
I intend to remove the rear emblem from my '11 LTD (Gen 1.5) and plasti-dip it. The chrome ring around the emblem has pretty much peel off completely. I know how to get it removed and painted and all, but I have questions about placing it back on the hatch. I know it just sticks on with double sided tape but will removing it necessitate replacing the double sided adhesive? If so, what kind of tape/adhesive did you all use? If I just stick it back on will it be secure enough to STAY on? Also, I would like to use flat back plasti-dip. Does plasti-dip require putting a sealer over it? Our Texas sun can really beat the heck out of painted finishes and I am wondering of I should use a UV resistant sealer over the plasti-dip. Any feedback would be appreciated. Thanks!
Many logos and even body trim parts from all mfr's (as well as large portions of your appliances) are now permanently assembled using adhesive transfer tape and double sided adhesive foam tape exclusively from a family of products provided by 3M: the VHB (for Very High Bond) line. Very effective, very expensive (only as a material cost, long term they save a ton of money on assembly as well as failure and service rates). There are a huge variety of products with very specific requirements (substrate, shear strength spec, age and operating temp etc) such that you really want to know which specific product was used in the first place. This is not a Gorilla glue does all kinds of application. Further, if and when you define exactly which 3M VHB product you require, buying less than a case from a 3M industrial/automotive dealer is a real problem. A single roll of 1/2" x 50yd of a mid-grade VHB dble sided foam is about $60 and up. 72 rolls per case.
OK, thanks for the info but maybe a bit too in-depth for my question. I just need to know once I remove the emblem, will the existing adhesive tape be sufficient to stick it back on and keep it on. If not, I can find something that will. I just wanted to know if anyone had done this already.
You will need to replace the adhesive. When you use fishing line and a heat gun/hairdryer to remove the emblem, the adhesive tape will get destroyed and you will have to clean it up before applying the new tape. You can buy small rolls of VHB heavy duty 3M double sided adhesive tape from Amazon:
https://www.amazon.com/dp/B00JR4D7AA/ref=psdc_15710291_t1_B002JOVUO0
Edited by roots57
Roots, thanks. That's the info I was looking for. I know that Gorilla makes a double sided spongy tape but wasn't completely comfortable in deciding to use it. I ordered a roll of the 3m VHB tape.
Any advice on possibly needing a sealer or UV resistant top coat on plasti-dip? I'm thinking maybe not but as I mentioned, our Texas sun can beat the heck out of car finishes.
I only used plasti-dip on my rear badges, I prefer vinyl wherever possible. My advice on using plasti-dip is to make sure its nice and warm outside and make sure the plasti-dip can is brought up to temp as well. If its too cold, it will come out like snot and the finish will be really orange-peel. I applied like 5 or 6 coats of black and then 3 or 4 coats of the glossifier to make it look more like real paint. My badges still look great after more than a year of washes and SoCal sun.
I'm removing my AVS Aeroskin hood protector if anyone wants it, its still in perfect condition. I'll even re-apply it with new 3M adhesive tape too, just need to pay for shipping ($20-$25 I'm thinking) and its yours. Brand new they cost about $65 +tax & shipping, PM me if anyone is interested.
May I ask why you are removing it? Plasti-dip is a great tool, because you don't need to remove the emblem at all. Just tape a square around the emblem, put your coats of plasti-dip on it, remove the tape after the last coat. let it dry, then just peel it away. Any small areas that the plasti-dip gets into can be removed with a toothpick. no hassle of getting the emblem off and back on again.
do NOT put anything over the plasti-dip. it defeats the purpose of the plasti-dip and usually messes up the finish. I live in central texas and use plasti-dip quite often. 20k miles on my harley and my front forks have been plasti-dipped the whole time with zero issues.
I had the wheels plasti-dipped for approximately 11k miles and they still looked great when I finally took the plasti-dip off. With that being said, after that period of time, the dip wasn't "peeling" like it was supposed to. to fix that issue, i sprayed 2 more coats on top of the previous coats, waited for it to dry, and it peeled no problem.
here is a how to, showing you that there is no need to remove the emblem:
Well you know, I suppose I don't have to actually remove the emblem. I just figured it would be easier to remove it and plasti it then re mount it. I've watched a few vids on removing it and it doesn't look that difficult so that's why I decided to do it that way. But in seeing how easily plasti-dip is removed I may re-think removing the badge. hmmm.... It would require masking off the rear hatch but I suppose that's not that difficult to do.
I do think that I will use the plasti-dip glossifier however. The Tux Black really looks great after being washed and waxed and I'm thinking that a round oval of flat black might detract from that look.
Thanks for responding!
I finally got the rear emblem Plasti-Dipped and it looks great. I also used some Glossifier to make it shine. I eventually decided to remove it from the hatch to avoid any issues with overspray. Pretty simple with some super duper Harbor Freight trim removal tools I have. I used some of the 3M adhesive tape mentioned above to re-stick it on. I think its pretty secure. I like the blacked out look much better than the fading and peeling chrome that surrounded the oval.
Thanks for everyone's input. I'm pleased with how it came out.
