Noise from engine when shutting down
1004ron
Occasionally when after parking and turning off the ignition I hear what sounds like a fan coasting down, with a metallic rattle.
It could be one of the cooling fans or one of the two turbo chargers - anyone else hear this, and if it is the turbos coasting down, should I be concerned or does this sound normal?
Got 22K miles on it - it can only be heard if your outside the car near the front.
Cooling fans... I believe that there's a TSB on the issue
Thanks, that got me searching for the TSB and found this:
TSB #SSM 45936 NHTSA ID #10091422
Summary: SOME 2015-2016 EDGE AND 2016 MKX VEHICLES BUILT ON OR BEFORE 6/11/2016 MAY EXHIBIT A NOISE FROM THE ELECTRIC COOLING FANS, MOST NOTICEABLE RIGHT AFTER THE ENGINE IS TURNED OFF AS THEY SPIN DOWN TO A STOP. IF THE NOISE CAN BE PINPOINTED TO T
Can't find more detail.
NHTSA ID Number: 10091422
Manufacturer Communication Number: SSM 45936
Summary
SOME 2015-2016 EDGE AND 2016 MKX VEHICLES BUILT ON OR BEFORE 6/11/2016 MAY EXHIBIT A NOISE FROM THE ELECTRIC COOLING FANS, MOST NOTICEABLE RIGHT AFTER THE ENGINE IS TURNED OFF AS THEY SPIN DOWN TO A STOP. IF THE NOISE CAN BE PINPOINTED TO THE COOLING FAN MOTOR, INSTALL A NEW COOLING FAN MOTOR AND SHROUD F2GZ-8C607-E WHICH WAS RELEASED FOR SERVICE TO RESOLVE THIS CONCERN.
  • Like 3
