2012 Ecoboost Oil Leaks
tamugrad2013
As requested here is a redacted copy of the service report. They did have to replace the crank case assembly apparently and also the turbo feed lines were improperly installed when the turbo was replaced last summer which caused the minor leaking. The APIM information is also on the report but that is fairly well covered.
oil leak.pdf
