Rusty Tucker Posted April 6, 2018 Report Share Posted April 6, 2018 Can it connect with the iPhone 10. The current version is horrible. Quote Link to comment Share on other sites More sharing options...
pintokid Posted April 8, 2018 Report Share Posted April 8, 2018 My upgrade using a 32G USB drive worked fine. And I have noticed the new WIFI prompts as others have mentioned. That seems like a bug that I expect will be corrected in the next update. Ā This update requires nowhere near 32G free. Maybe 2G for this update. 1 Quote Link to comment Share on other sites More sharing options...
Okie Posted April 9, 2018 Report Share Posted April 9, 2018 From what I remember if you check for updates once and then turn wifi off it will no longer prompt you. I don't get the prompts on either vehicle I updated to 3.0. I also have never had it install an update over Wifi. It checks but never downloads them. My assumption is when it checks your VIN it doesn't see it as a valid Sync 3 vehicle. Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 10, 2018 Report Share Posted April 10, 2018 Hmmm... In reading all the posts so far what I am perceiving is that doing an upgrade from v2.x to 3.0 provides little additional functionality and a lot of headache with bugs, glitches, and general irregularities. I'm sure there must be some back-end fixes that a user does not see, but my LTD w/ version 2.3 seems to be performing just fine (other than the reverse cam grid lines disappearing) so... what incentives might there be for me to upgrade? Maybe I have a case of 'leave well enough alone.' 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 10, 2018 Report Share Posted April 10, 2018 Hmmm... In reading all the posts so far what I am perceiving is that doing an upgrade from v2.x to 3.0 provides little additional functionality and a lot of headache with bugs, glitches, and general irregularities. I'm sure there must be some back-end fixes that a user does not see, but my LTD w/ version 2.3 seems to be performing just fine (other than the reverse cam grid lines disappearing) so... what incentives might there be for me to upgrade? Maybe I have a case of 'leave well enough alone.' Doesn't your Edge have MyFord Touch (aka Sync 2)? Ā The discussion here is regarding Sync 3,the newer system that came on 2016+ Edges which is completely different from previous years. Ā If your your still on V2.3 from the old system, then the latest upgrades to the old system do really fix bugs & stability issues. Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 10, 2018 Report Share Posted April 10, 2018 Ah, yes. I think I might be confused. Yes, my Edge does have MFT and I am on v2.3 (per the Ford Owner site). Other than the backup gridlines everything is functioning fine now. Once I determine which ELM327 wired USB device I need to get I intend to go into Forscan (I have already downloaded the latest version) and address that. Thanks for the clarification. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 10, 2018 Report Share Posted April 10, 2018 3.8 was the first really stable MFT release. But if 2.3 is working for you I wouldn't mess with it. Quote Link to comment Share on other sites More sharing options...
candurin Posted April 10, 2018 Report Share Posted April 10, 2018 Once I determine which ELM327 wired USB device I need to get I intend to go into Forscan I would strongly recommend this one: Ā https://www.amazon.com/dp/B01F0GVBWY Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 11, 2018 Report Share Posted April 11, 2018 Ah, yes. I think I might be confused. Yes, my Edge does have MFT and I am on v2.3 (per the Ford Owner site). Other than the backup gridlines everything is functioning fine now. Once I determine which ELM327 wired USB device I need to get I intend to go into Forscan (I have already downloaded the latest version) and address that. Thanks for the clarification. Ā It is better to check the version in the settings' system information. Compare the version number to this list. Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 11, 2018 Report Share Posted April 11, 2018 Omar, man, your posts have been really helpful. Thanks much. I did check the MFT info via system settings in the vehicle and from your post ^ I determined this info for my vehicle: Ā CCPU: 15128 3.8 SyncGen2_3.08:15128.EA.10_Product Released October 02 2015 (Compatible up to A8, B8 & F6 SD Cards) Rev 4 (Patched) latest Nav Version (5.67.6) Released September 2015 Ā Per the link you provided there is one other later version 16180 Sync Gen2_3.10.16180 Released November 2016. The ford.owner.site does not list an update available for my VIN so 15128 3.08 is what I'm staying with. Ā Thanks again for the info. Ā Candurin: I ordered the EML327 reader you recommended. Should be here on Friday and I will address my gridline issue. May start doing some customization stuff if I get brave! Ā Man, I love this group! Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 11, 2018 Report Share Posted April 11, 2018 ford.owner.site stopped showing any updates for MFT for some time now. The only official way to update it to go to a dealer. Alternatively, you can find the files & download them for other sources. As far as I know, there are no real advantages for V3.10 over V3.8. Here is one source, you'll need the US version. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 11, 2018 Report Share Posted April 11, 2018 If you really had MFT 2.3 you would be pulling fuses every 2-3 days. I donāt recall anything significant in 3.10 so I wouldnāt worry about upgrading. Ā If it aināt broke, donāt fix it! Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 11, 2018 Report Share Posted April 11, 2018 I think you're right about that. I'm not going to try to upgrade. Ā I did get notice that my ELM327 OBDII will be delivered today. When I get it I'm going to try do a camera recalibration and hope to restore the gridlines. I'll post my results. Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 12, 2018 Report Share Posted April 12, 2018 Success!! The ELM327 adapter came and I ran the Backup Camera Recalibration procedure (there's a utoob vid out there on exactly how to do it) and my gridlines are back!! Yay! Thanks for all the help guys!! Ā I'll try not to be tempted to start futzing with other stuff with Forscan! 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 12, 2018 Report Share Posted April 12, 2018 OK, so is Ford playing some kind of cruel joke here? Last night I run the recalibration procedure and gridlines re-appear and everything is fine This morning I drive around a bit then need to shift to reverse, AND NO GRIDLINES! WTF? I will run the procedure again in awhile and hope that I sticks this time. If not, I have no explanation for what is going on. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted April 12, 2018 Author Report Share Posted April 12, 2018 Could you take the discussion of MFT and gridlines to its own thread please. This is about SYNC3 and the V3.0 software being released. I really hate getting notifications that aren't related to it. Plus you might get better input to help solve your issue. Thanks 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 12, 2018 Report Share Posted April 12, 2018 No problem. Sorry about that. Will start another thread. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted April 16, 2018 Author Report Share Posted April 16, 2018 Rumor is WAZE released an update for IOS users today and that it now works stand-a-lone with Sync3 V3.0 via applink. I haven't personally tried it yet. Quote Link to comment Share on other sites More sharing options...
FordGuy1 Posted April 16, 2018 Report Share Posted April 16, 2018 (edited) Rumor is WAZE released an update for IOS users today and that it now works stand-a-lone with Sync3 V3.0 via applink. I haven't personally tried it yet. I just updated Waze this morning and tried it on my 2017 Ford Edge Titanium running Sync3 v3.0 (with Navigation) and it did not show up in the AppLink. iPhone 7 connected to USB and Waze running on phone. Ā iHeartRadio now works without the need of the iHeart for Auto. Ā April 17 addition: I tried again to get Waze to work and succeed. I had to have Sync update mobile apps serval times and then reconnect the phone by USB and it then worked. I then turned off the car and left it to go into the house and add favorites to Waze, when I returned and tried it again it worked fine. Ā Is there a way in Waze to use the address of contacts that are on your phone? *** I found out how to do this *** Ā Also found out that if my phone is connected to bluetooth and I connect my wife's by USB Waze will work from her phone. The thing is that while using Waze that's connected to her phone and inputting a destination on the car display there is a clicking sound for each input. If I switch her phone to bluetooth connection and use Waze by the USB then there is no clicking sound. I hope in future revision to either Ford or Waze that the buttons on the bottom of the car display when using Waze would scroll down like when using the Ford navigation, this allows the map display to be bigger. Edited April 18, 2018 by FordGuy1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 16, 2018 Report Share Posted April 16, 2018 I read that the Waze update on ios only work on Sync 3 with Navigation. The Nav icon would be replaced by Waze. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted April 16, 2018 Author Report Share Posted April 16, 2018 I can't get it to work on either nav or non nav that I have. Read plenty of people have it working on both nav and non nav though. 1 Quote Link to comment Share on other sites More sharing options...
veener79 Posted July 21, 2018 Report Share Posted July 21, 2018 I just bought at 2018 Sport with Nav. I got it home and connected it to my home Wifi while in the garage. My Wifi router is right on the other side of the wall. It shows there is an update to JR3T-14G423-CA software. It starts to download and I get this error "Previous Scan was incomplete, please try again when convenient". Is this normal to get this error a few times? Will it auto update while the car is off? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 21, 2018 Report Share Posted July 21, 2018 Wi-if updates still donāt work. You need to go to owner.ford.com and use a USB drive for now. Quote Link to comment Share on other sites More sharing options...
veener79 Posted July 24, 2018 Report Share Posted July 24, 2018 Wi-if updates still donāt work. You need to go to owner.ford.com and use a USB drive for now. Ā I did look and it showed my system is up to date on their site. But my car is saying it has an update. It is so weird. I have a ticket open with Ford. Quote Link to comment Share on other sites More sharing options...
FordGuy1 Posted September 1, 2018 Report Share Posted September 1, 2018 I have a 2017 Ford Edge Titanium with Navigation that was updated to V3.0 in May 2018. Today when I checked the Ford owner site there was a new version of V3.0 for download. The one in may was JR3T-14G381-AM 3.0.13 this one is now 3.0.14. I downloaded it to USB and installed it in my Edge, it took only about 15 minutes to install. I don't know what it fixed or changed, nothing obvious but everything seems to work OK. Ford should get better at telling what revisions change or update. The general information in the Edge now shows it at 18093. Ā I hope that they fixed the USB so that it doesn't re-index about every 3rd time that I restart the vehicle. Time will tell. Quote Link to comment Share on other sites More sharing options...
