KingpinEdge Posted March 16, 2018 Report Share Posted March 16, 2018 When I turn on AC and push max AC on...I get Luke warm air on driver side of car and passenger side is cold. I don't have dual climate control. I have found and watched blend actuator move with each temperature click change on temperature dial. My vents all cycle through the dash floor and defrost ok. I also see actuator move for recirculation of air. Can it be the air blend or a.c. charge. I knew it was good but will check tomorrow on AC charge. 1 Quote Link to comment Share on other sites More sharing options...
Tolman Posted June 29, 2018 Report Share Posted June 29, 2018 Did you ever figure this out? I am having the same issue Quote Link to comment Share on other sites More sharing options...
LilCe98 Posted August 20, 2018 Report Share Posted August 20, 2018 I'm having the same problem. The driver's side is cold, but the passenger side is hot. I have dual climate control, but I'm not sure if that matters. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 20, 2018 Report Share Posted August 20, 2018 Either a recalibration of the unit, or a shortterm unplugging of the deficient blend door actuator may work for you. Quote Link to comment Share on other sites More sharing options...
