atekido Posted March 15, 2018 Report Share Posted March 15, 2018 I forget what the technical name is for our little flaps that open and close depending on speed for aero drag efficiency. Is there any way to test these ourselves without having a camera mounted on the grill? Reason I ask is my Torque app showed me a possible Module failure with mine but I'm not actually sure if anything is wrong or if it is just a compatibility issue with the app reading a PID wrong. Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 15, 2018 Report Share Posted March 15, 2018 (edited) On 3/15/2018 at 3:50 PM, atekido said: I forget what the technical name is for our little flaps that open and close depending on speed for aero drag efficiency. Is there any way to test these ourselves without having a camera mounted on the grill? Reason I ask is my Torque app showed me a possible Module failure with mine but I'm not actually sure if anything is wrong or if it is just a compatibility issue with the app reading a PID wrong. when the car is cold...like over night....start the car up and run over to the gril with a light and look in, you should see them cycling Edited March 15, 2018 by Special_K 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted March 15, 2018 Author Report Share Posted March 15, 2018 (edited) oh never knew that thanks! i will get a chance to do it probably in a couple days when a cool front moves in lol. unless you just mean the car itself just doesn't need to have been ran for a while then ill check tonight haha! Edited March 15, 2018 by atekido Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 15, 2018 Report Share Posted March 15, 2018 (edited) The Active Grille Shutters are meant to speed up engine warmup, and then reduce drag, hence improving fuel economy. Taken from a 2014 FSM Active Grille Shutter System The active grille shutter system (when equipped) is comprised of the grille shutter assembly and the grille shutter actuator. The active grille shutter system is primarily used to maximize fuel economy by reducing aerodynamic drag on the vehicle. In addition, the system is used to control coolant temperature, HVAC system performance and exhaust emissions depending on the vehicle speed. The system is also used to shorten engine warm-up time, increasing engine efficiency and providing heat to the vehicle occupants in a timely manner. PCM inputs/outputs used for controlling the active grille shutter system are the: Engine Coolant Temperature (ECT) sensor Intake Air Temperature (IAT) sensor A/C pressure transducer Accelerator Pedal Position (APP) sensor ABS module, messages sent over the High Speed Controller Area Network (HS-CAN) Engine cooling fan motor Engine oil temperature Grille Shutters The grille shutters are several "slats" or "blinds" connected to one another by a linkage system. One of the individual grille shutters is fixed to the grille shutter actuator. When the grille shutter actuator moves, it moves the attached shutter which causes the other linked shutters to move. The individual grille shutters are not available for service separately, they are serviced with the grille shutter assembly. Grille Shutter Actuator The grille shutter actuator is a smart motor which receives position requests from the PCM via a Local Interconnect Network (LIN). One of the grille shutter blinds connects to the grille shutter actuator using a retainer. The grille shutter actuator can be serviced individually or as an entire assembly, which includes the grille shutters, grille shutter actuator, retainer and grille shutter housing. The grille shutter actuator positions the grille shutters based on commands received from the PCM. The full range of movement of the grille shutter actuator is a total of 90 degrees from fully closed to fully open. The actuator moves the grille shutters to 1 of 16 positions (approximately 6 degrees between positions) when requested by the PCM. Edited March 15, 2018 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted March 16, 2018 Author Report Share Posted March 16, 2018 Active Grill Shutter, that is what i was trying to remember. Thanks for the info. Not i just have to remember to actually go and look at the grill before its been running a while. 1 Quote Link to comment Share on other sites More sharing options...
