Jgaburri Posted March 8, 2018 Report Share Posted March 8, 2018 On my wifes 2009 Ford Edge I have replaced bothe upper struts, both lower control arms, both inner and outer tie rods, and the rack and pinion. Once I bled the power steering fluid and started the car the horn started to blow on its own and the steering wheel now turns in both directions by itself. Has anyone seen this issue or has heard of it yet please help. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 8, 2018 Report Share Posted March 8, 2018 (edited) You didn't get the high pressure and return lines reversed, did you? Edited March 8, 2018 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 8, 2018 Author Report Share Posted March 8, 2018 There is only one way for the lines to go on plus the lines are the same as the one I previously removed Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 8, 2018 Author Report Share Posted March 8, 2018 Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 8, 2018 Author Report Share Posted March 8, 2018 Double checked the high pressure line from the pump to the banjo bolt and the return from the rack to the cooler Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 14, 2018 Author Report Share Posted March 14, 2018 The have now replaced the broken clock spring and it is still doing the same thing and the airbag light wont go out Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 14, 2018 Report Share Posted March 14, 2018 You sure you did not hook the lines up wrong? 1 Quote Link to comment Share on other sites More sharing options...
CTFordfan Posted March 15, 2018 Report Share Posted March 15, 2018 I would suspect a faulty rack and pinion unit. Internal leaks. Was it a reman or new unit? Quote Link to comment Share on other sites More sharing options...
CTFordfan Posted March 15, 2018 Report Share Posted March 15, 2018 Compare the old unit to the new one. Are the jumper lines correct. They may be reversed unintentionally. Also some units need a vacuum pulled in the system to remove all the air. 1 Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 15, 2018 Author Report Share Posted March 15, 2018 One line connects through a banjo fitting the return line is through a slip on hose if these are backwards they came from the factory backwards. The lines on the new rack and pinion are the exact same as the old rack and pinion Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 15, 2018 Author Report Share Posted March 15, 2018 How does one pull a vacuum on the rack and pinion Quote Link to comment Share on other sites More sharing options...
CTFordfan Posted March 16, 2018 Report Share Posted March 16, 2018 How does one pull a vacuum on the rack and pinion With a mighty vac and some fittings. Do a quick search and the procedure will come up. Sorry i am not good at posting links. Air in the system can cause this and the vac procedure will remove all of it. I guess some do not self bleed by turning lock to lock. Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 16, 2018 Report Share Posted March 16, 2018 Following because i am interesting in finding out if it is parts failure or installation error. Great learning experience. 1 Quote Link to comment Share on other sites More sharing options...
Jgaburri Posted March 24, 2018 Author Report Share Posted March 24, 2018 I pulled a vacuum on the system and followed the procedure in the chilton manual and it still does the same thing. Did some more testing that lead me to a possible steering wheel valve in the rack to be bad. Change the rack once again and still having the issues just not as bad was atleast able to drive the car. It is hard to run slightly and then after moving so far it goes on its own and you have to fight it then. The only thing left is a power steering pump could this be causing the issue 1 Quote Link to comment Share on other sites More sharing options...
