The 2011 does not have a button to disable courtesy lamps with the door(s) open. Do all the lights not light up with an open door? Even the rear cargo light? If yes, then it is either a fuse or maybe dark mode was enabled. Dark Mode is a setting in the body control module to do just that, but it needs a dealer to program it or using a PC and a software called ForScan with a compatible adapter.
Now, if only the front lights do not work while the rear/cargo do work, then it might be a disconnected wire in the overhead console (behind the lights).
