FWD - Rear Wheel Hub Bearing Assembly
  • 4 weeks later...
Spoke with Mac yesterday and he said they aren't. I am quite curious as to why the original part had a ridged ring, Even after watching MacT's video, I did see some slight ridges on his original hub/bearing. I did see that the AWD ones do not have that ridge. I am also going to check with my parts vendor to double verify.
Spoke with Auto Anything and their distributor. Auto Anything is reaching out to Timken to see why these bearings did not have the ABS/Speed sensor ring. I am following up with them today to see where they are.
In the meantime, I am going to print the mailing labels for these bearings and send them back for a refund.
I don't quite get what you are asking.
All the pictures I've seen of rear bearings for a Gen 1 FWD Edge show no external tone ring- it looks like the ABS sensor plugs into the plastic on the back of the hub, so the tone ring must be internal.
If it's an AWD Edge, then a shaft has to go through the bearing- so there's no room for the FWD style design. Therefore they press a tone ring on the halfshaft and mount a sensor to the spindle to read that.
FWD Rear Hub:
https://www.rockauto.com/en/moreinfo.php?pk=2924862&cc=1434490&jsn=465
AWD Rear Hub:
https://www.rockauto.com/en/moreinfo.php?pk=2925744&cc=1434490&jsn=464
AWD Rear Halfshaft:
https://www.rockauto.com/en/moreinfo.php?pk=9125224&cc=1434490&jsn=537
I'll be replacing the rear hub/bearings on our 2010 Edge soon. Been making a growling noise for a while now that sounds like it's coming from the rear, and the MPGs are way down. Just short of 60K miles.
Edited by IWRBB
Exactly,
Mine is a Gen 1.5 with almost 160k.
I am also working with the vendor to see where they went wrong because when the original was removed, there was no plastic cover over that tone ring. That's another thing I am finding confusing. If that's supposed to be there, why did it come off?
  • 4 weeks later...
