MC, KYB or Moog Strut Mounts?
Which brand would be a better choice on the Front Strut Mounts for my 07 FWD Edge? MC, KYB or Moog? The Moog & KYB look little different than the MC's. Also, MC or KYB for the Struts correct? And would Stock Springs still be any good with 250k on em?
Is the MC Struts themselves good or would aftermarket be fine for those to? Also, should I purchase New Strut Mount Bushings?
Not sure where you are getting information on front strut bushings. You can replace your struts and strut bearing mounts with MC parts or as I prefer I use MC strut bearing mounts and KYB Excel G struts. KYB does sell quick struts now for the Edge. The strut bearing mount will be KYB and I have no reason to believe the strut bearing mount will be any less quality than the MC parts.
Ā
KYB will provide a firmer ride and IMO better handling. The OEM will be a softer ride.
