enginjoe Posted March 6, 2018 Report Share Posted March 6, 2018 What the heck is this code? I can't find anything on the interwebz for the Edge 2.7l ecoboost for this code. I saw a thing from Ford about having to reprogram the PCM on an F150 with the 3.5L... Anyone know? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 6, 2018 Report Share Posted March 6, 2018 (edited) The f150 reference. Could be a PCM calibration error. A Rousch manual says possibly "P25B0 Fuel Level Sensor “A” Stuck" Ford E-Series and F-Series ProductsDescription The SRM reads Fuel Level Sender (FLS) input and broadcasts it to the IC and PCM. If the vehicle is driven a considerable distance and the FLS value doesn't change, the fault is set. Possible Causes Fuel Level Sender fault Wire fault between FLS and SRM SRM fault Symptom The driver is unaware of a low fuel condition. tsb15-0040.pdf Edited March 6, 2018 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
