edsasdelli Posted February 22, 2018 Report Share Posted February 22, 2018 If I trade my 21 inch wheels and tires with another Ford Edge 20 inch wheels and tires how hard is it to resync the TPMS? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 22, 2018 Report Share Posted February 22, 2018 Should be able to drive it and have it reset automatically (same gen Edge?). Typically you drive for 10 miles or more at speeds above 20mph to get the TPMS to recognize the "new" sensors. If that does not work, a training tool is needed, although i have seen it done with a strong magnet instead. Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 22, 2018 Report Share Posted February 22, 2018 Maybe I'm just the lucky one: http://www.fordedgeforum.com/topic/21556-2016-sel-winter-wheels/page-1 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 23, 2018 Report Share Posted February 23, 2018 One if mine has auto-forget. Or maybe it just goes to sleep. Good part is, it wakes up and relearn's in about 20 miles. Quote Link to comment Share on other sites More sharing options...
roots57 Posted February 23, 2018 Report Share Posted February 23, 2018 I basically had the same situation, my edge came with 20" wheels then I bought an edge 21" wheel/tire package with new TPMS sensors. Since then, I've swapped the wheels back and fourth a few times and they always sync up after driving for few minutes. Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 8, 2018 Report Share Posted July 8, 2018 2017 Sport. Up until now I've had the dealership rotate tires when doing a lube service, but plan on doing all services myself from now on, including the tire rotation. After rotation which procedure should I use to teach the TPMS which wheel is in what location, and is the learning tool worth the $25. Ford 8C2Z-1A203-A TPMS Transmitter Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 11, 2018 Report Share Posted July 11, 2018 You can try the magnet trick to train the TPMS, videos available on YT. If it does not work, the tool has been a surefire way to train the sensors. Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 11, 2018 Report Share Posted July 11, 2018 (edited) 2017 Sport. Up until now I've had the dealership rotate tires when doing a lube service, but plan on doing all services myself from now on, including the tire rotation. After rotation which procedure should I use to teach the TPMS which wheel is in what location, and is the learning tool worth the $25. Ford 8C2Z-1A203-A TPMS Transmitter The below procedure worked on my 2016 Edge. I would only add that I had initially over inflated the tires by ~5 psi and drove it for a few minutes to make sure the sensors were not in sleep mode. Edited July 11, 2018 by omar302 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 11, 2018 Report Share Posted July 11, 2018 That’s a pretty smart way to do it. Kudos to the engineers. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted January 3, 2019 Report Share Posted January 3, 2019 Is there a way to get the TPMS system to notify you when you have reached the correct air pressure? Quote Link to comment Share on other sites More sharing options...
