enigma-2 Posted June 19, 2018 Report Share Posted June 19, 2018 $30 on Amazon (free prime shipping). https://www.amazon.com/dp/B000NUB132/ref=cm_sw_r_cp_apa_loikBbVH9MHWB My 09 MKX came with gold from the factory. Dealer told me they needed to change it when they discovered it in an oil change. Told me Ford had discovered that it didn't have sufficient protection to prevent rusting or corrosion, and they needed to use a special flush to remove every part of the gold when going to green. 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 19, 2018 Report Share Posted June 19, 2018 Thanks E but I think my 11 takes this one: https://www.amazon.com/Motorcraft-VC10A2-Anti-Freeze/dp/B008B5VBBS/ref=sr_1_2?s=automotive&ie=UTF8&qid=1529436039&sr=1-2&keywords=motorcraft+specialty+green+engine+coolant Still a good deal through Amazon so I'm gonna order a few for some drain and refills. Quote Link to comment Share on other sites More sharing options...
chefduane Posted June 19, 2018 Report Share Posted June 19, 2018 ^ I took a look at that listing and saw that it said "with bittering agent." I was trying to think 'what the heck do they mean my that' when my dog walked under my legs and the light bulb went on. Also, as long as another brand coolant lists that it meets or exceeds the Ford spec (like Zerex Glysantin G-05) would Ford's fluid be necessarily required? Notwithstanding dealer issues with warranty claims of course. My '11 is out of warranty. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 19, 2018 Report Share Posted June 19, 2018 Personally I would stay with Motorcraft as I really don't know if the others are better or not. But if you do change, even if it states it's compatible, I would still do a complete flush. Not all coolants play well together. Also if you change, consider labeling the coolant fill with the actual coolant being used. Memory fades over time. 2 Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 20, 2018 Report Share Posted June 20, 2018 Personally I would stay with Motorcraft as I really don't know if the others are better or not. But if you do change, even if it states it's compatible, I would still do a complete flush. Not all coolants play well together. Also if you change, consider labeling the coolant fill with the actual coolant being used. Memory fades over time. Im having a conversation with my mechanic who is doing the engine swap on my 07 3.5 and he was going to go with Ford recommended coolant which I believe he stated was orange. Should I tell him to go wit green instead? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 20, 2018 Report Share Posted June 20, 2018 Orange is incorrect, Green is fine. Orange came into play, I want to say 2012 MY. Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 20, 2018 Report Share Posted June 20, 2018 (edited) Orange is incorrect, Green is fine. Orange came into play, I want to say 2012 MY. I went to my local Ford Dealer and pick up some green concentrate. What they had in Green was VC-5.... so I bought 2 gallons. $17.00 a gallon. Its Green.... I hope its the right stuff. I find the price very odd for a dealership because Amazon wants 30,00 a gallon for the same thing. Edited June 20, 2018 by clt750 Quote Link to comment Share on other sites More sharing options...
chefduane Posted June 20, 2018 Report Share Posted June 20, 2018 (edited) Yes, certainly a complete flush. Never mix coolants, i.e. add orange to a low reservoir filled with green (or vice versa). Probably even best to drain then flush with distilled water then refill with new coolant. Edited June 20, 2018 by chefduane Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 20, 2018 Report Share Posted June 20, 2018 The correct green coolant is this one https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Specialty%20Green%20Engine%20Coolant%20with%20Bittering%20Agent&category=A/C%20and%20Engine%20Cooling%20Products VC10 The one you got, VC5, is incorrect https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Premium%20Prediluted%20Antifreeze/Coolant&category=A/C%20and%20Engine%20Cooling%20Products Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 20, 2018 Report Share Posted June 20, 2018 The correct green coolant is this one https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Specialty%20Green%20Engine%20Coolant%20with%20Bittering%20Agent&category=A/C%20and%20Engine%20Cooling%20Products VC10 The one you got, VC5, is incorrect https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Premium%20Prediluted%20Antifreeze/Coolant&category=A/C%20and%20Engine%20Cooling%20Products Great Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 20, 2018 Report Share Posted June 20, 2018 The correct green coolant is this one https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Specialty%20Green%20Engine%20Coolant%20with%20Bittering%20Agent&category=A/C%20and%20Engine%20Cooling%20Products VC10 The one you got, VC5, is incorrect https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Premium%20Prediluted%20Antifreeze/Coolant&category=A/C%20and%20Engine%20Cooling%20Product What I bought is not diluted though as you have posted in that link. This is what I bought https://www.amazon.com/Genuine-Ford-VC-5-Concentrated-Antifreeze/dp/B000NUB132 Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 20, 2018 Report Share Posted June 20, 2018 (edited) I am getting mixed signals as I saw Enigma-2 post a link that shows the VC5. Then I see Fishx65 posts a link that shows them ordering the VC10. Is this a certain year thing with the different coolants?? I need to figure this out as I need to drop this off at my mechanics tomorrow morning to wrap up this night mare. I just called the dealer where I bought the VC5 and they are telling the VC10 variant is used for diesels. So I dont know. Edited June 21, 2018 by clt750 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 21, 2018 Report Share Posted June 21, 2018 Attached is a chart showing what models/years came with what coolants: coolants.pdf Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 21, 2018 Report Share Posted June 21, 2018 IF your considering changing from one coolant type to another, you may be interested in the official Ford procedure for doing so. It's for 2007 through 2009 (my car) but should provide guidance as to Ford officially recommends as any mixing of different types will create a clogged cooling system. 2009 MKX Cooling System Corrosion.pdf Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 21, 2018 Report Share Posted June 21, 2018 (edited) Attached is a chart showing what models/years came with what coolants: Thanks that lools like great info but its telling me Yellow.... or is it gold. Basically it makes it a little more confusing to me. Did I not read correctly that Ford came out and said the yellow/gold was not to be used and that green should be used as replacement? This is a low mileage dry engine that I am having swapped out. Supposedly out of a 2007 Edge. So no oil, no coolant. Edited June 21, 2018 by clt750 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 21, 2018 Report Share Posted June 21, 2018 I am getting mixed signals as I saw Enigma-2 post a link that shows the VC5. Then I see Fishx65 posts a link that shows them ordering the VC10. Is this a certain year thing with the different coolants?? I need to figure this out as I need to drop this off at my mechanics tomorrow morning to wrap up this night mare. I just called the dealer where I bought the VC5 and they are telling the VC10 variant is used for diesels. So I dont know. According to the chart that E posted your 2007 should take the Gold coolant. I'd be half tempted to use a universal product from Zerex or Prestone if I was starting fresh. I think I remember high mileage boy (Mac) using a universal Zerex coolant in his Edges. Quote Link to comment Share on other sites More sharing options...
clt750 Posted June 21, 2018 Report Share Posted June 21, 2018 Ack yes, I had it basackwards. The car came with gold and they switched out to green. Appearently it affects 2007-2009 Edge's and MKXs. This is what is confusing Enigma-2. But if that chart is correct is does state it should be Yellow. Quote Link to comment Share on other sites More sharing options...
chefduane Posted June 21, 2018 Report Share Posted June 21, 2018 (edited) Enigma, thanks for posting that .pdf.! I had to go back and do a VIN check to find my DoM (11/11/10) on my '11 LTD to then determine I need VC10 - Specialty Green. (Apparently prior to 7/11/11 DoMs take Specialty Green and post 7/11/11 DoMs require Orange.) However, I'm still thinking that if a coolant meets Ford's 'Specialty Green' spec WSSM97B55-A that it should be OK. Not sure if the Peak that Mac uses meets Ford spec but he's got 250k on Lulubelle so me must be doing something right. I think the same oil discussion can be applied to coolant: Use the correct spec (whatever brand), change it at regular intervals (full flush recommended) and err on the side of lower mileage intervals. (I do mine at 30k.) Heading to Galveston tomorrow from Dallas. About 350mi / 700 round trip. Trip report with particulars will follow in a few days. That is all. EDIT: After a fairly exhaustive search I have been unable to find any coolant that states that it meets Ford VC-10A2 (WSSM97B55-A) spec. All will say that it won't void a warranty and meets manufacturers recommendations but none specifically say they meet the spec. So it looks like Specialty Green is the only option. However, I was able to find it at Rock Auto for $21.79/Gallon. With the 5% discount code it's only $20.70/Gallon. That's the best price I could find anywhere. Edited June 21, 2018 by chefduane 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 21, 2018 Report Share Posted June 21, 2018 Specialty Green is the only "green" coolant viable for the the Edges that came equipped with the Gold (yellow) or Green coolants. So VC10 product is what you are looking for. VC5 DOES NOT WORK!!! Put the Specialty Green coolant in your "dry" engine if using Motorcraft. Yes, Peak Universal Extended Life meets/exceeds Ford specs for our Edge/MKX. Basically all these universal products have resorted to listing the ASTM specs: Meets ASTM D-3306 and ASTM D-4340Specialty Green Meets or exceeds the requirements of WSS-M97B55-A and ASTM D 3306 Quote Link to comment Share on other sites More sharing options...
chefduane Posted June 25, 2018 Report Share Posted June 25, 2018 Ok, just so I'm clear... Peak Universal can be used in place of Ford Specialty Green? Quote Link to comment Share on other sites More sharing options...
I'manedgeowner Posted June 26, 2018 Report Share Posted June 26, 2018 Interesting read. I was totally ignorant of any issues with the pump or coolants with the Edge or the 3.5. This raises some questions for me. First, are there any issues with going to the waterless coolant? I've gone to it in all the cars because it's by far better but a maintenance job I hadn't gotten to yet with my Edge. Second, I didn't know my 2008 has an internal pump running off the timing chain. Let's face it, it's a really bad idea. Is anyone offering an external electric pump kit? I know some are offered for Eco Boost engines used in Rally Cars but the 3.5 or not I don't know. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 26, 2018 Report Share Posted June 26, 2018 (edited) My 09 MKX came with gold but my local dealer told me that I should switch over to green. The gold was found to NOT provide sufficient protection. Note that the gold must be COMPLETELY washed out of all parts of the cooling system. Not one trace of the gold must be left to mix with green. It will form crystals and clog the smaller passages. The dealer had a specific process to follow in converting over the system. . Edited June 26, 2018 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted June 26, 2018 Report Share Posted June 26, 2018 My '11 came with the green but I do not know if it was the Ford Specialty Green. So I can assume (or not?) that Peak green meets the ASTM D-3306/4340 and should be ok? 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 26, 2018 Report Share Posted June 26, 2018 Peak should be fine. And yes OEM was Specialty Green, starting sometime in the 2009 MY IIRC. macbwt has been using Peak in both his 2011's for quite some time now. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 26, 2018 Report Share Posted June 26, 2018 If you 3.5 came with gold, the local dealer told I should switch over to green. The gold was found to NOT provide sufficient protection. Note that the gold must be COMPLETELY washed out of all parts of the cooling system. Not one trace of the gold must be left to mix with green. It will form crystals and clog the smaller passages. The dealer had a specific process to follow in converting over the system. So I was looking at the coolant chart you posted earlier. Is it the yellow coolant that doesn't provide proper protection? Looks like later models switched to Dark Green for a short time and then to Orange. My brother has a 2009 with the yellow and I was thinkin about letting him know about this. Quote Link to comment Share on other sites More sharing options...
