candurin Posted February 20, 2018 Report Share Posted February 20, 2018 (edited) So as my car ages (only 66k!), its starting to develop a creaking sound (kinda like cracking knuckles) when I start to move the car or make a turn. Its definiely more pronounced when cold, but certainly does it from a dead stop. Seems like its coming from the wheel wells (front and back seem to make it). Perhaps some type of bushing needs to be replaced? I know you guys enjoy diagnosing issues solely from a vague description of a random noise. Edited February 20, 2018 by candurin 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted February 21, 2018 Report Share Posted February 21, 2018 I'm going with strut bearing. My 2011 has been crying for a while now but I'm ignoring her. Mine is loudest when turning right into a parking spot. 1 Quote Link to comment Share on other sites More sharing options...
candurin Posted February 21, 2018 Author Report Share Posted February 21, 2018 Its also noticeable when I hit a bump, pothole etc. Ill have a look. Any tell-tale signs from a visual standpoint? Quote Link to comment Share on other sites More sharing options...
evh Posted February 21, 2018 Report Share Posted February 21, 2018 When it is stopped and you push up and down on it does it make a sound? My noise was sway bar links. It would make the noise when bounced. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 21, 2018 Report Share Posted February 21, 2018 If you notice excessive lean into corners, that is more indicative of SB links. Otherwise, given that you are in NJ, I would say time to do suspension (struts/shocks/mounts) at all 4 corners. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 22, 2018 Report Share Posted February 22, 2018 "Cracking knuckles"? Sounds like strut tower bushings. They can size and not rotate, forcing the spring to jump from point-to-point instead of rotating smoothly. As above, new struts, bushings and shocks. 1 Quote Link to comment Share on other sites More sharing options...
candurin Posted February 26, 2018 Author Report Share Posted February 26, 2018 It is absolutely more pronounced from a dead stop. Really a popping noise once I start moving. Ill get around to it eventually. Quote Link to comment Share on other sites More sharing options...
