toast1850 Posted February 16, 2018 Report Share Posted February 16, 2018 Hi all, I have a 2014 Edge SEL and noticed in my instrument cluster that Instant Fuel economy is missing. This was an option on my previous 2013 SE that I enjoyed having. I'm thinking it can be turned back on via Forscan software but I don't know what value would need to be changed. I'm guessing it would be a setting in the IPC module. If anyone might know what value needs to be changed, it would be greatly appreciated. Instrument Panel Control Module My 2014 Edge IPC 720-01-01 E580 2BBC 2499 IPC 720-01-02 C42A A042 908A IPC 720-01-03 002B IPC 720-02-01 0309 0700 3D IPC 720-03-01 5553 D3 IPC 720-04-01 3030 7C00 0008 IPC 720-04-02 0000 0000 002D Instrument Panel Control Module My previous 2013 Edge IPC 720-01-01 E580 29BC 2497 IPC 720-01-02 C42A A042 908A IPC 720-01-03 002B IPC 720-02-01 0309 0700 3D IPC 720-03-01 5553 D3 IPC 720-04-01 3030 6000 00EC IPC 720-04-02 0000 0000 002D Quote Link to comment Share on other sites More sharing options...
toast1850 Posted February 23, 2018 Author Report Share Posted February 23, 2018 Does anyone know what value could be changed to get this setting back? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 23, 2018 Report Share Posted February 23, 2018 should be configurable through the menu buttons for the IPC. Both levels of cluster have the option to display instantaneous FE. No options under Trip 1/2? Quote Link to comment Share on other sites More sharing options...
toast1850 Posted February 23, 2018 Author Report Share Posted February 23, 2018 No there aren't any options under trip 1 or 2. By the way, this IPC is identical to my previous SE. It's not the cluster with 2 screens on left and right. Quote Link to comment Share on other sites More sharing options...
toast1850 Posted February 23, 2018 Author Report Share Posted February 23, 2018 Options available on mine are average fuel, distance to E, trip timer, and gallons used. Quote Link to comment Share on other sites More sharing options...
toast1850 Posted March 8, 2018 Author Report Share Posted March 8, 2018 So it appears Instant fuel economy is available on my cluster because after entering diagnostics mode I found this. I just can't figure out how to make it show in the main screen. Even if I use my bit values from my 2013 it will accept them in Forscan but never shows up. I wonder if the dealership could make this show up? 1 Quote Link to comment Share on other sites More sharing options...
