Sync System changes Function by itself
I've been having a problem with the Sync System changing modes by itself. I use Carplay so with my iphone connected, I press the Ford Sync button, then Audio and will select FM and an HD preset. I'll listen a few minutes and the music quits playing, when I check the Audio button i will find that FM is no longer selected and instead another function - usually Sirrus has is selected. I reselect FM and listen a few minutes until the music quits - once again the Source has changed from FM to (usually) Sirrius. Anyone else have this issue?
