driver21565 Posted February 10, 2018 Report Share Posted February 10, 2018 Just a quick question about my purge valve. I had the valve replaced after the code came on and all is good . The problem is that the valve keeps making a ticking noise opening closing very fast constantly. the person who repalced it says this is common on my truck. 2013 ford edge awd 3.5 Thanks Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 10, 2018 Report Share Posted February 10, 2018 Did they use Motorcraft or aftermarket? 1 Quote Link to comment Share on other sites More sharing options...
driver21565 Posted February 10, 2018 Author Report Share Posted February 10, 2018 motocraft. from the dealer. at first when they changed it the check engine light was on. after the change all was good and then some time later it started to make the noise 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted February 11, 2018 Report Share Posted February 11, 2018 Might be defective. None of the new purge valves I installed made noise. 1 Quote Link to comment Share on other sites More sharing options...
glock7 Posted February 13, 2024 Report Share Posted February 13, 2024 Did you ever figure it out? Quote Link to comment Share on other sites More sharing options...
