2007 Edge slipping
rkierstead8
First of all, I want to say thank you for the wealth of information that is on this forum. I've been reading through some topics and I plan to continue doing so until I find a resolution. The reason for this post is to get some advice specific to my problem, so here goes.
We've had our edge for about a year now and It has been leaking from the PTU for some time. (not sure how long). It is bad enough that we have a small puddle in the spot where we park in our garage. When I saw the spot I did some preliminary research and knew about some of the PTU issues with these cars, but now I think I'm at a cross roads where I HAVE to do something.
We've had issues with a loud clunking noise when going into reverse and at time while accelerating onto the interstate. Yesterday her car wouldn't crank because the battery terminal was loose. I'm sure that is purely coincidental, but after I came and tightened it up for her and got her headed home, the transmission started to slip. This is especially bad around 20-25MPH and is fairly consistent.
I've read about some sensor issues that may cause issues, but I'm lost on where to start. I know financially I can't spend thousands on a fix for this thing especially if I can't pin point the problem.
That's where I'm hoping this community will help point me in the right direction.
If the PTU is bad could it be causing the trans to slip?
Are there known internal issues with the transmission that might cause something like this?
Please help!
Edited by rkierstead8
Any idea on the best place to find the sensors?
I'd like to find them in a store so I can try to replace them this weekend, but that isn't looking likely.
Edit: Still can't find a store, but can anyone clarify if these are the correct part numbers before I order them. It's hard to believe that they half the cost compared to the others that I have found.
https://smile.amazon.com/gp/product/B072PPY6DH/ref=ox_sc_act_title_1?smid=A3B850ZGIPDG3A&psc=1
https://smile.amazon.com/gp/product/B071FF1L6H/ref=ox_sc_act_title_2?smid=A3B850ZGIPDG3A&psc=1
Would also do the Transmission Range Sensor at the same time, to fix the clunk into reverse.
If you can take apart the valve body for inspection so much the better. Be sure to know where every bolt goes because a couple of them are different sized than the others. Same with checkballs if you have the VB apart.
Get the filter/gasket assembly for the Solenoid Body Assembly. It's like $11 so well worth it to keep those shift solenoids clean. SBA might need replacement if shifting does not clear up with TSS/OSS.
And oh, make sure the trans is in Neutral and battery is disconnected before beginning work. You will be glad to avoid doing the work twice.
Also, make sure the Edge is ready for inspection status. The battery situation may have set off a PCM relearn. You can check the I/R status without any extra equipment, as specified in the owner's manual.
To determine if the
vehicle is ready for I/M testing, turn the ignition key to the ON position
for 15 seconds without cranking the engine. If the Service engine
soon indicator blinks eight times, it means that the vehicle is not
ready for I/M testing; if the Service engine soon indicator stays on
solid, it means that the vehicle is ready for I/M testing.
The OBD-II system is designed to check the emission control
