17 Edge under body cover
CTFordfan
just traded the 11 Edge for a used 17 Titanuim 2.0. It only has 14 k however with only 1 oil change done by previous owner it was missing a screw holding the felt under body cover on. As I changed the oil upon closer inspection I see the screw is actually broken off in the fastener. Likely an over zealous tech with a cordless impact. So I need the screw and the body fastener it screws into. This is the rear of the cover and it also holds up the front of a metal cover. I saw I diagram here on the site but it does not show that particular fastener.
Can anyone help with a part number of that body nut??
Any help is much appreciated.
  On 2/9/2018 at 7:42 PM, CTFordfan said:
The dealer- looking at the same drawing I was, could not tell which type nut this position is. They only had the red plastic nuts in stock but i thought this spot had a metal nut- I will know soon enough when I can get under there again. Anyone know for sure?
Take a look, I think you need the following parts, HC1, HN1, and HS1 (hardware for the 6P013 Air Shield)
HC1 is the Clip and it is part number W718150
HN1 is the Nut and it is part number W702438
HS1 is the Screw w/ Spring Washer and it is part number W702413
Should cost you around $10.00 in total for one of each item
Edited by roots57
  • Like 3
So the dealer provided a pkg of red plastic insert nuts- wrong part, i have none of these in any position.
Dealer provided screws with a torx head- wrong part, i have none of these in any position.
Dealer provided- after I sent my wife back again and told them i need a metal insert, a small metal snap in insert that was correct and it accepts a 4.2 x 1.41 x 20 mm screw with built in washer.
So again, even the dealer cannot tell which fastener is in what position with this dismal diagram. I had to tell them what was there, odd.
While i was under there i also put two of those inserts where the plastic push in fastners are, and added 2 screws. i could not get them to snap in tight. So now I need only the 7mm driver to remove the cover.
Anyone who changes oil must hate these covers.
