ssander7 Posted February 7, 2018 Report Share Posted February 7, 2018 Hi Everyone, I'm new to the forum and just trying to get an idea on where to start with my investigation of my issue. My Edge started this rattling noise about a week ago. I noticed that during a cold start (I live in Florida) when we had a slight cold spell the car would start, but upon acceleration it begins a rattling sound and slightly stalls, I let up on the gas, give it a sec then it goes fine. As the car continues to roll and "warms up" I don't hear it as often. Since it began, its gotten worse, with the rattling and stalling. It seems to happen up to about 40-45 mph. In other words, it doesn't happen at all once I'm on the freeway or traveling above that mph. Any ideas. My husband mentioned the transmission as a possibility? Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 7, 2018 Report Share Posted February 7, 2018 Welcome! The 2 most common culprits for rattles from the engine are a] a non-Motorcraft oil filter, and b] timing system, specifically stretched/loose timing chain(s) Normally the filter rattle goes away after startup, but the timing system rattle can persist. First, try using the Motorcraft FL400S filter and see if that makes a difference. If it does not, checking with a mechanic's stethescope in the front cover/timing cover area will be worth it. If the rattle is confirmed as coming from there, a big job (can be DIY) likely lies ahead: timing chains, phasers, tensioners, VCT solenoids and water pump. So, start with a new oil filter and go from there. Make sure the oil level is also at the top of the hashmarks on the dipstick, and that the oil is clean (not muddy or dirty). 1 Quote Link to comment Share on other sites More sharing options...
ssander7 Posted February 7, 2018 Author Report Share Posted February 7, 2018 Great! Thank you very much. I'll let you know how it goes. 1 Quote Link to comment Share on other sites More sharing options...
