ABS, Traction Control, and Check Engine Lights
whitedragon551
Im back with another new issue on my wife's Edge. We recently replaced the passenger side axle due to a broken tone ring and recently had a coolant leak due to faulty radiator fans.
The new issue is is that the ABS, Traction Control, and Check Engine lights all come on while she is driving on the highway. It only happens at highway speeds around 70MPH. They all go away once she parks and comes back later. Driving on roads at less than high way speeds the lights never come on. So far we havent been able to tie it to hitting bumps.
Any ideas? My first thought was a wheel bearing or wheel speed sensor or another bad tone ring somewhere.
Edited by whitedragon551
I was thinking the same thing, but if it was loose wires bumps would also set it off. It currently seems to be speed related.
I'm thinking wind would be pushing the wires in a different direction (horizontal?) than a bump (vertical).
Hard to say though. Maybe the sensor is flaky and can't keep up with the speed above 70.
