hborsman Posted January 28, 2018 Report Share Posted January 28, 2018 how do I disable the double horn beep when using the remote start in my 2017 Edge Quote Link to comment Share on other sites More sharing options...
Mikula Posted January 28, 2018 Report Share Posted January 28, 2018 are you using it correctly? hit lock button once, and the other button twice. are you hitting both buttons twice? Quote Link to comment Share on other sites More sharing options...
ben senise Posted January 28, 2018 Report Share Posted January 28, 2018 remote start shouldn't cause the car horn to honk. as Mikula asks above, are you pressing the lock button twice? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 28, 2018 Report Share Posted January 28, 2018 On a gen 2, I believe a double horn honk means the hood is open (or the switch isn't registering closed). I think it also means your foot is on the brake peddle, but that shouldn't be your problem here. I don't know if they continued the same pattern on yours. Quote Link to comment Share on other sites More sharing options...
hborsman Posted January 28, 2018 Author Report Share Posted January 28, 2018 It's a factory remote start. You need to press the lock button twice and after the second beep, the car starts. I want to disable the horn beeping during the process. Quote Link to comment Share on other sites More sharing options...
Mikula Posted January 28, 2018 Report Share Posted January 28, 2018 like i stated. you're doing it wrong. 1 Quote Link to comment Share on other sites More sharing options...
hborsman Posted January 28, 2018 Author Report Share Posted January 28, 2018 That's not my key fob, Mine has a lock, unlock and horn, The first press of the lock, locks the door. The second press makes the horn beep. The third press makes the horn beep and starts the car. I guess it's a way to let you know you have successfully started your car when you can't see the lights, But the beeping horn is annoying to my neighbors Quote Link to comment Share on other sites More sharing options...
Gortty-Pilot Posted January 28, 2018 Report Share Posted January 28, 2018 Your remote start sounds like its an aftermarket kit. Ford OEM remote start keys have a dedicated button. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted January 29, 2018 Report Share Posted January 29, 2018 The factory remote start from Ford involves a dedicated start button on the fob - press lock at least once to lock the vehicle then press the remote start button twice to initiate remote start. There are several aftermarket remote start kits which use the "press lock button 3 times" method so that you don't have to carry a separate fob for the remote starter - Fortin and MPC are two well known brands. Your dealer probably installed one of those aftermarket kits prior to delivery. The Edge, along with almost every other car ever equipped with remote power locks, locks all doors on the first press of the lock button on the fob and then provides an audible confirmation (horn or electronic beep) that it's locked when the lock button is pressed a second time. It may be possible to disable the horn beep for the remote start (depending on which aftermarket model it is) but the first beep for the double lock button press will always be there. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 29, 2018 Report Share Posted January 29, 2018 On 1/28/2018 at 11:19 PM, Gortty-Pilot said: Your remote start sounds like its an aftermarket kit. Ford OEM remote start keys have a dedicated button. This. If that actually starts your car then you’re stuck with the honks because that’s Ford’s way of letting you know you’ve locked the vehicle. Clever design by the aftermarket remote start because it uses the OEM remote, but the side effect is the double honk. No way around that unless you change it for the factory remote start. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 29, 2018 Report Share Posted January 29, 2018 If you are up to changing As Built Data with ForScan, this might work: Quote Link to comment Share on other sites More sharing options...
