headlight question
hybridoutlaw
New user with a rather stupid question. Most vehicles that I have modified in the past (usually HID conversions) have fuses related to the low and high beams. I've searched high and low for said fuses on the 2016 ford edge and cannot seem to find anything. Would anyone here know if said fuses exist?
Thank you for your time and help on this.
The fuse would be in the battery fuse panel, labeled something like Body Control Module. But power could be coming through other fuses as well. (You MUST have a service manual to know for certain).
If the lights are not working on one side I would suspect either thd bulbs or ballast (if HID). But that's only a guess. As your under warranty run it over to your dealer and let him sort it out.
