edsasdelli Posted January 21, 2018 Report Share Posted January 21, 2018 vehicle runs great, no dashlights or problems of any kind....however, when I scanned it to put the LMS tune in, it shows the above 2 codes? B1215 says rear license lamp assembly but mine is working fine? I cleared them and loaded the LMS tune. Quote Link to comment Share on other sites More sharing options...
Mikula Posted January 21, 2018 Report Share Posted January 21, 2018 What did you use to scan it? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 21, 2018 Report Share Posted January 21, 2018 (edited) Very likely rust/corrosion at the license plate lamp assembly. If there are 2 assemblies, replace them both, being sure to apply a light coating of dielectric grease prior to final installation. That should take care of the B1215 code ... permanently. If your Edge is an AWD, then the P164D likely means that the PCM is missing the identification info for the RDU, and it needs to be programmed in. Edited January 21, 2018 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
edsasdelli Posted January 21, 2018 Author Report Share Posted January 21, 2018 On 1/21/2018 at 3:29 PM, Mikula said: What did you use to scan it? It came up on the LMS tuner when I went to load in the 91 perf tune. Quote Link to comment Share on other sites More sharing options...
edsasdelli Posted January 21, 2018 Author Report Share Posted January 21, 2018 On 1/21/2018 at 4:08 PM, WWWPerfA_ZN0W said: Very likely rust/corrosion at the license plate lamp assembly. If there are 2 assemblies, replace them both, being sure to apply a light coating of dielectric grease prior to final installation. That should take care of the B1215 code ... permanently. If your Edge is an AWD, then the P164D likely means that the PCM is missing the identification info for the RDU, and it needs to be programmed in. thanks for the license plate asy info.....regarding the PCM missing the RDU ID info, is that going to affect driveability or operations? or can I just get it done next time in for service? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 21, 2018 Report Share Posted January 21, 2018 Not a clue, seems to have been operating ok thus far this winter? Then ya, can wait till you go in for the next service. There MIGHT be different strategies the PCM/AWD module employs based on the ID, like it is for the transmission, but IDK. Quote Link to comment Share on other sites More sharing options...
