2007 vs 2008 wheels
prairiedad
My wife hit a curb and cracked a wheel on a 2008 Ford Edge Limited. I found someone with takeoff wheels from a '07 that appear to be the same design and everything. He is unsure of the size (He needs to get them out of the garage and it's buried in snow).
Is there any chance of a different wheel bolt pattern between the 2007 and 2008 Edges? From what I can tell, all were 5 x 4.5". Can you tell me if I might be wrong?
The bolt pattern is the same for 2006-2014 (5x114.3mm.) and then changed beginning in 2015 to present (5x108 mm.)... so anything prior to 2015 will fit your Edge.
Good luck,
Claude. ;)
Actually, the 2011-2014 wheels will not fit 2006-2010s. The lug pattern is the same, but the hub bore is smaller on the 11-14s. You could go the other way and run 2006-2010 wheels on 2011-2014 (hopefully with hub rings to center them).
