dddedge Posted January 19, 2018 Report Share Posted January 19, 2018 Hi Mact and everyone that's reading this post..I have an 07 Edge with 137,000 miles.(It sat in my garage 2 days without me starting it prior to this happening) this morning it didn't start right up as it usually does, instead it cranked over fast (battery is good) but didn't want to start, I cranked it about 10 seconds, then stopped cranking, then maybe another 10 and stopped cranking, then on the 3rd try of cranking over good and fast it finally started up. I drove it about 2 miles and it ran great with no problems. came back home and shut it off, it started right back up that time and several more times with no problem. I let it sat for 2 1/2 hours, went out and started it right up again no problem, drove about 4 miles to get some Lucas fuel injector cleaner, added it to the tank and filled up with gas, I was at almost 3/4 tank before fill up. shut it off and restarted a few more times with no problem...could it be my purge valve failing? I didn't fill it with gas before this happened. could it be a fuel injector leaking down or the fuel pump leaking down after the Edge sits a couple days. any help is appreciated...Thanks in advance.. I had a hard time trying to figure out where to post a new topic on this forum, I could reply to other topics but couldn't find any where to post a new topic except here in the Welcome Forum. Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted January 23, 2018 Report Share Posted January 23, 2018 Sounds like the fuel pump isn't holding pressure when sitting for a long time. You can see if this is the problem by turning the ignition on and not cranking the engine the next time it sits for a while. Try this a couple of times and then crank the engine and see if it fires up normally. I had a ford contour that did this and I needed to turn the ignition and wait for the pump to stop priming before starting it. This worked for over a year before the pump just crapped out. 1 Quote Link to comment Share on other sites More sharing options...
