Tom Champagne Posted April 15, 2008 Report Share Posted April 15, 2008 I'm getting a set of new shoes on friday(ASA JH8 and 275-45-20's)from Tire rack and I would like to know if there is a over the counter tool to re-set my TPMS without having to go a tire dealer. Maybe it's too expensive,but I would like to do this procedure myself,instead of going to tire place twice a year. Any thoughts? Maybe a Ford tech might be listening? TIA Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted April 15, 2008 Report Share Posted April 15, 2008 I'm getting a set of new shoes on friday(ASA JH8 and 275-45-20's)from Tire rack and I would like to know if there is a over the counter tool to re-set my TPMS without having to go a tire dealer. Maybe it's too expensive,but I would like to do this procedure myself,instead of going to tire place twice a year. Any thoughts? Maybe a Ford tech might be listening? TIA Hi Tom. :D Yes, there is a tool available. You can purchase it at your local Dealer, or other Ford Parts Supplier. I am sure that it can also be found on ebay. Just be sure you get the right tool for the Edge TPMS system, as there are different versions. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
Craiger Posted April 15, 2008 Report Share Posted April 15, 2008 Ya, I would love to know how much the tool cost. Just put my new 22s on and had to have the dealer re-calibrate the new TPMS. Will have to pay every spring & fall when I swap my summer & winter tires to get this done....what a pain. I had originally thought the re-calibration could be done easily through a setting on the dash...unfortunately I was wrong. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted April 15, 2008 Report Share Posted April 15, 2008 (edited) Ya, I would love to know how much the tool cost. Just put my new 22s on and had to have the dealer re-calibrate the new TPMS. Will have to pay every spring & fall when I swap my summer & winter tires to get this done....what a pain. I had originally thought the re-calibration could be done easily through a setting on the dash...unfortunately I was wrong. Hi Craiger. :D I do not know the cost offhand, but believe I have seen some versions priced at about $20 (not 100% sure though, since I do not have TPMS). Try calling Team Ford Parts at 1-800-791-6436. Of course, to get a general idea on the MSRP of the tool, you can always call your Dealer Parts Department (if they are competent). Good luck. :beerchug: PS - Again, be sure you get the correct tool for the TPMS system on your vehicle, as the tool can vary from vehicle to vehicle and system to system. Edited April 15, 2008 by bbf2530 Quote Link to comment Share on other sites More sharing options...
Craiger Posted April 15, 2008 Report Share Posted April 15, 2008 $20!! That's alot cheaper than I was thinking. Definitely going to have to look into picking one of those up. I paid the dealer $42.50 to do it...and that's only once. Going to have to pay that twice per year so the tool might be a wise investment. Thanks! Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted April 15, 2008 Author Report Share Posted April 15, 2008 Thanks for the replies guys...as Craiger noted..it would be a wise investment to buy this tool. I've got new "chrome clad" wheels coming in this week..so while I'm there,I'll ask about the tool. Quote Link to comment Share on other sites More sharing options...
NYEdge Posted April 16, 2008 Report Share Posted April 16, 2008 I was about to order the same kind of tool that the Ford mechanics use (approx. $400.00), but i found a reset tool on Ebay for around $25.00 I ordered one and it should be here soon so I'll post the results. Heres a link: http://cgi.ebay.com/ebaymotors/Ford-Tire-P...sspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted April 17, 2008 Author Report Share Posted April 17, 2008 I also found one on ebay and if I'm the highest bidder(25.00),I'll get in about a week. Please post your results per your post and how easy it weas to operate. Quote Link to comment Share on other sites More sharing options...
NYEdge Posted April 21, 2008 Report Share Posted April 21, 2008 Well I got the TPMS tool and it works great! It was extremely easy to get into the "Learn" mode of the Edge and program the TPMS sensors. That is if you have the proper procedure to get into the "Learn" mode. The tool does not come with any directions, but I wasn't really expecting it to either. I watched a technician at the dealer scan my wheels so I wrote down the procedure. That was about 3 months ago and I can't find the paper I wrote it down on :wacko: , so I searched online and came across a link on how to program the TPMS on a 2007 Ford Mustang. The procedure is exactly the same and the link is: http://home.ptd.net/~safari/mustang/fsm/Training.pdf The whole process takes about 2 minutes and it's done. I highly recommend this tool to anyone that wants to switch out the stock wheels and tires with custom wheels and tires during the spring & winter. You will also need to reset the TPMS sensors when you rotate your tires. If you do the rotating yourself, its not only more convenient but you also save around $45.00 in dealer fees to scan the tires. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted April 25, 2008 Author Report Share Posted April 25, 2008 I'm getting a set of new shoes on friday(ASA JH8 and 275-45-20's)from Tire rack and I would like to know if there is a over the counter tool to re-set my TPMS without having to go a tire dealer. Maybe it's too expensive,but I would like to do this procedure myself,instead of going to tire place twice a year. Any thoughts? Maybe a Ford tech might be listening? TIA Just got my tool and it works great as well. One question tho...since my winter tires will be stored in the garage,along with the new sensors that I just set,will the old sensors affect the ones that I just set? Quote Link to comment Share on other sites More sharing options...
NYEdge Posted April 25, 2008 Report Share Posted April 25, 2008 Not at all. It's like parking next to another Ford in a parking lot. Your car does not recognize any other tire sensor because you registered a specific sensor to your vehicle. This tool works great! Quote Link to comment Share on other sites More sharing options...
Craiger Posted April 25, 2008 Report Share Posted April 25, 2008 That's great news...I'm gonna have to get one of these tools. If you guys have a link to the ones you have, it'd be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
druck52 Posted April 25, 2008 Report Share Posted April 25, 2008 Your spare tires will not affect the tpms unless you are trying to reprogram the ones on your car next to the spare ones, that could cause problems because it could read the spares. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted April 25, 2008 Author Report Share Posted April 25, 2008 Not at all. It's like parking next to another Ford in a parking lot. Your car does not recognize any other tire sensor because you registered a specific sensor to your vehicle. This tool works great! Thank you for your reply. I also think this tool is awesome. Thanks again. Quote Link to comment Share on other sites More sharing options...
