Ford Edge 2011 Misfiring and occasionally engine off
Aodiaka
Few weeks back I started notice my ford edge 2011 SEL was jerking when not in motion sometimes the engine goes of on the dashboard you see low engine oil warning sign.
The fuel filter was seen clogged with dirt this was replaced but misfiring continues further check revealed P0019 crankshaft position - camshaft position correlation (bank 2 sensor B) for ford edge.
How do I proceed to fix it.
How many miles on your Edge?
What oil are you using? Brand, weight, etc. What filter? Any leaks from the engine oil pressure switch area (just above the A/C compressor, to the left of the oil filter)?
The P0019 error code is most likely caused by failing VCT solenoid(s) or other timing components. Have you had any issues with starting the Edge? Like an extended crank for instance.
May just need spark plugs and PCV valve to fix the misfires, especially if the plugs are fouled from poor fuel. Change the air filter, clean the MAF sensor (with MAF or electrical parts cleaner) and clean the throttle body. Check the PCM coil driver resistance to rule out PCM errors.
The oil warning light can come on for numerous reasons. It could be the PCM software needs updating. Or the engine has stalled/is about to stall then restarts. Or you have just cold started your engine. If the warning light STAYS on, then the software update might be necessary OR there is real hardware failure.
The last issue i saw related to that was as simple as a bad wire leading to the sensor (in my case it was the crank sensor)
i replaced both sensors first, and it didn't fix the issue. after running around trying to find what else it could be, i traced the wires and found one that was damaged. replaced it and no problems after that.
What oil are you using? Brand, weight, etc. What filter? Any leaks from the engine oil pressure switch area (just above the A/C compressor, to the left of the oil filter)? Not really consistent with oil sometime Mobil 1.
The P0019 error code is most likely caused by failing VCT solenoid(s) or other timing components. Have you had any issues with starting the Edge? Like an extended crank for instance. Yes experiencing extended crank.
