Sync 2 MFT USB media hub question
I wanted to know if Ford provided a pigtail kit for the Sync 2 USB media hub that sits in the center console on factory equipped Edges with MFT. My 2014 Edge has the base hub with the Auxiliary line in and USB port. I'm wanting to swap out the hub so I can spice in to use the sd card for navigation since I converted to the 8" screen. I have everything working except the replacement USB hub.
I've done some searching online and found two pigtail kits but I'm not sure if they are compatible or correct.
WPT-930 9U2Z-14S411-DA and WPT-1047 9U2Z-14S411-ZA
Can someone please let me know if there is a pigtail kit to wire the hub? I attached a picture of the hub for reference.
Thank you.
Edited by toast1850
Have a look here: http://www.2gfusions.net/showthread.php?tid=4050
Or, this may be another (albeit very pricey) option: https://www.4dtech.com/4-to-8-pnp-conversion-harness-for-sync-2-3/(it should work on the edge, no problem).
You may even be able to buy just the harness from here: https://www.infotainment.com/collections/all/products/4-myford-to-8-myford-touch-custom-upgrade
Edited by candurin
Yes I found that document while searching. I knew the wpt-1239 is used for sync 3 hubs but I can't afford to go with sync 3 right now. I know the sync 2 hub is a 12 cavity pin, but its just narrowing down if there is a pigtail kit for it. There are so many 12 cavity pigtails in that PDF that I'm not sure which one is correct. I really hope someone has an answer. Thanks
