Anyone have detailed info on the 3.5 TI-VCT Duratec motor?
AntDeek
Okay so I need some help. I have two vehicles at home with the Duratec 35. One is my 13 Edge, the other is my Dads 17 Explorer. I am trying to see the timing benefit of 93 octane in my Edge vs 87 octane in his Explorer.
Using FORSCAN to look at timing, how come I am seeing negative intake timing values in degrees? Shouldnt it be a positive number?
Like negative 30,degrees timing. Shouldnt it be a positive number? Exhaust timing shows a positive number
Read this link https://en.wikipedia.org/wiki/Ford_Duratec_engine, it will tell you the history. Someone did a dyno test on the 3.7L Mustang, comparing 87 octane with 93 octane gas. 93 octane produced 7 more horsepower to the wheels than 87 octane. Sensors will 'automatically' adjust the timing when you use a higher or lower octane gas. I 'think' for many years Ford's owner manuals have stated to use premium gas for better performance. :)
  On 1/16/2018 at 12:44 AM, WWWPerfA_ZN0W said:
One of the references that is very good to start with
http://www.supersixmotorsports.com/_pdf/2016/cyclone-tech-v2.pdf
Wards has an article on the 2011 update to Ti-VCT also. You can look at articles on the Mustang 3.7 to gain additional insight.
do you have a link to the wards article? i cant seem to find it.
  • 6 months later...
  On 3/11/2018 at 12:20 AM, WWWPerfA_ZN0W said:
Cannot find the Wards article either, may be under premium content now, but here is something ...
http://www.myfordedge.com/specs/2011-ford-edge-powertrain.php
Here's one on the first gen 2.0 Ecoboost used in the Edge
http://wardsauto.com/technology/ford-4-cyl-ecoboost-powerful-versatile-and-efficient
Heads up everyone, the Ward's article is back online
https://www.wardsauto.com/news-analysis/ford-motor-co-duratec-35-35l-dohc-v-6
