vega Posted January 15, 2018 Report Share Posted January 15, 2018 Does anyone know if installing a remote start counts against the administrative key count? I have three keys as admin keys. I also have installed a remote start. When I tried to add a key, the car said it had 4 keys programmed and that is the limit. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted January 15, 2018 Report Share Posted January 15, 2018 What remote start did you install? Quote Link to comment Share on other sites More sharing options...
candurin Posted January 16, 2018 Report Share Posted January 16, 2018 Yes. A FORD remote start is defaulted to an admin key. You can program it as a MyKey, if you want. 2 Quote Link to comment Share on other sites More sharing options...
vega Posted January 17, 2018 Author Report Share Posted January 17, 2018 Thank you for the information. Quote Link to comment Share on other sites More sharing options...
vega Posted January 17, 2018 Author Report Share Posted January 17, 2018 What remote start did you install? A cheap one from ebay that works with your regular fob, Not too bad very limited to the same range as your fob. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted January 17, 2018 Report Share Posted January 17, 2018 (edited) Then no it won't count as a key unless it had some process to learn a key which I don't think those do? Edited January 17, 2018 by jmr061 Quote Link to comment Share on other sites More sharing options...
vega Posted January 17, 2018 Author Report Share Posted January 17, 2018 Then no it won't count as a key unless it had some process to learn a key which I don't think those do? Well, I double checked and in my case it counts as a admin key. This was a fully plug and play unit that took less that 10 minutes to install, eight of which was the cover from the steering wheel bottom. 1 Quote Link to comment Share on other sites More sharing options...
