vrdublu Posted January 12, 2018 Report Share Posted January 12, 2018 Just wondering if anyone knows which 2 of the 3 wires that go to the driving light/turn signals to tap to prevent turn signal hyper flashing? Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 12, 2018 Report Share Posted January 12, 2018 I suggest you use ForScan to disable the light out feature wich will then make LED signals flash normally without any resistors. 1 Quote Link to comment Share on other sites More sharing options...
vrdublu Posted January 12, 2018 Author Report Share Posted January 12, 2018 I have, and yet I still get the hyperflashing. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 12, 2018 Report Share Posted January 12, 2018 There are front and rear settings. You need to disable the front or rear depending on which your installing. 1 Quote Link to comment Share on other sites More sharing options...
vrdublu Posted January 12, 2018 Author Report Share Posted January 12, 2018 I don't remember front and rear but I have all turn signals led now. I'll have another look. Thx for the heads up. Quote Link to comment Share on other sites More sharing options...
vrdublu Posted January 17, 2018 Author Report Share Posted January 17, 2018 I did find that option in Forscan and had it turned off, although one of my rear turn signal LEDs is out. Apparently even though you turn the function off, you will still get hyperflashing if a bulb dies. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 18, 2018 Report Share Posted January 18, 2018 Do you mean that with the LED working you don't get the hyperflashing but when it is out you do? That is interesting. 1 Quote Link to comment Share on other sites More sharing options...
