onyxbfly Posted August 7, 2018 Report Share Posted August 7, 2018 Just received my sway-bar as well ..... and yes Jim its not installed yet! 2 Quote Link to comment Share on other sites More sharing options...
dmjarosz Posted August 8, 2018 Report Share Posted August 8, 2018 Boooo! Mine didnt come in today. So much for getting any sleep tonight... Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 8, 2018 Author Report Share Posted August 8, 2018 (edited) Status/Update: 08 Aug 2018Per John Wright (ADDCO Rep):All bars have shipped as of last Wk.Note: 1 extra bar remains available... Edited August 8, 2018 by snmjim 1 Quote Link to comment Share on other sites More sharing options...
THE_BOLT Posted August 8, 2018 Report Share Posted August 8, 2018 Had my bar sitting on the porch when I got home from work today! 1 Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted August 9, 2018 Report Share Posted August 9, 2018 awaiting the arrival of mine. We need new bolts for the bushing mounts? Quote Link to comment Share on other sites More sharing options...
veener79 Posted August 9, 2018 Report Share Posted August 9, 2018 Wow this new swaybar is heavy! Endlinks should be delivered Friday. Hope to get this all installed Saturday. Also got new front end endlinks. 1 Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 9, 2018 Author Report Share Posted August 9, 2018 On 8/9/2018 at 1:39 AM, NoDTMF said: awaiting the arrival of mine. We need new bolts for the bushing mounts? Not unless yours are excessively corroded. 1 Quote Link to comment Share on other sites More sharing options...
roots57 Posted August 10, 2018 Report Share Posted August 10, 2018 (edited) Received my bar this morning, just in time to get it installed this weekend! Any tips on a smooth install? On paper, removing the OEM bar and installing the new one is as straightforward as it gets. But, should I put the rear of the car up on jack stands for more room to work, then put my floor jack under the rear diff and jack it up to about normal ride height? I'm thinking this would take any potential preloading off the links. Would this be the easiest approach? Edited August 10, 2018 by roots57 Quote Link to comment Share on other sites More sharing options...
Xtra Posted August 10, 2018 Report Share Posted August 10, 2018 (edited) Yes!! My bar just arrived Edited August 10, 2018 by Xtra Quote Link to comment Share on other sites More sharing options...
veener79 Posted August 10, 2018 Report Share Posted August 10, 2018 On 8/10/2018 at 8:30 PM, Xtra said: Yes!! My bar just arrived You should be installing it instead of posting. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 10, 2018 Report Share Posted August 10, 2018 My brother received his sway bar yesterday! 1 Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 10, 2018 Author Report Share Posted August 10, 2018 On 8/10/2018 at 6:17 PM, roots57 said: Received my bar this morning, just in time to get it installed this weekend! Any tips on a smooth install? On paper, removing the OEM bar and installing the new one is as straightforward as it gets. But, should I put the rear of the car up on jack stands for more room to work, then put my floor jack under the rear diff and jack it up to about normal ride height? I'm thinking this would take any potential preloading off the links. Would this be the easiest approach? You're correct, lift anywhere but on the suspension...;-) 2 Quote Link to comment Share on other sites More sharing options...
veener79 Posted August 11, 2018 Report Share Posted August 11, 2018 So to jack up rear you can use the rear diff and put the jack stands on the pinch weld location? I also got front end links. Where do I put the floor jack to jack up the front? Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 11, 2018 Author Report Share Posted August 11, 2018 On 8/11/2018 at 12:08 AM, veener79 said: So to jack up rear you can use the rear diff and put the jack stands on the pinch weld location? I also got front end links. Where do I put the floor jack to jack up the front? Left & right front pinch weld points one at a time as you place jack stands. 1 Quote Link to comment Share on other sites More sharing options...
veener79 Posted August 11, 2018 Report Share Posted August 11, 2018 On 8/11/2018 at 1:44 AM, snmjim said: Left & right front pinch weld points one at a time as you place jack stands. OK but if I jack at the pinch welds there is no room to place the jack stands on the pinch welds. That is what I am trying to figure out. Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 11, 2018 Author Report Share Posted August 11, 2018 (edited) On 8/11/2018 at 1:48 AM, veener79 said: OK but if I jack at the pinch welds there is no room to place the jack stands on the pinch welds. That is what I am trying to figure out. Jack placement can be Fwd or Aft of jackstand placement point. As long as you're on the pinch weld. Be sure to use a cushion on the jack point i.e. rubber or wood block..;-) Edited August 11, 2018 by snmjim 1 Quote Link to comment Share on other sites More sharing options...
veener79 Posted August 11, 2018 Report Share Posted August 11, 2018 Ok sway bar is installed. After a test drive it helped a lot with getting the handling a lot more neutral mostly mid corner to exit. Feel in entry it has helped keep the body roll down. The OEM bar with ends links and bracket on it weighs 11lbs. This new one weighs 17lbs before even adding anything in to it! The install was not too bad. For some reason the passenger side end link to the lower control arm was harder to get out then the drivers side. Only two complaints. The black paint is very thin and scratches easy. Just getting feeding it through the back I saw some good scratches. Not sure if this will cause easy rusting. Noticed these do not have the lateral locks that the OEM bars do to help prevent the bar for moving side to side. Thinking I might get these from whiteline. Just wondering what size bar is the new one? https://www.whiteline.com.au/do_segue4.php?make=UNIVERSAL+PRODUCTS&model=SWAY+BAR+-+LATERAL+LOCK&model_final=SWAY+BAR+-+LATERAL+LOCK&vehicle=ALL 2 Quote Link to comment Share on other sites More sharing options...
snmjim Posted August 11, 2018 Author Report Share Posted August 11, 2018 (edited) On 8/11/2018 at 10:16 PM, veener79 said: Ok sway bar is installed. After a test drive it helped a lot with getting the handling a lot more neutral mostly mid corner to exit. Feel in entry it has helped keep the body roll down. The OEM bar with ends links and bracket on it weighs 11lbs. This new one weighs 17lbs before even adding anything in to it! The install was not too bad. For some reason the passenger side end link to the lower control arm was harder to get out then the drivers side. Only two complaints. The black paint is very thin and scratches easy. Just getting feeding it through the back I saw some good scratches. Not sure if this will cause easy rusting. Noticed these do not have the lateral locks that the OEM bars do to help prevent the bar for moving side to side. Thinking I might get these from whiteline. Just wondering what size bar is the new one? https://www.whiteline.com.au/do_segue4.php?make=UNIVERSAL+PRODUCTS&model=SWAY+BAR+-+LATERAL+LOCK&model_final=SWAY+BAR+-+LATERAL+LOCK&vehicle=ALL When you figure out the lateral locks let us know, i'm interested... Edited August 11, 2018 by snmjim Quote Link to comment Share on other sites More sharing options...
Xtra Posted August 12, 2018 Report Share Posted August 12, 2018 (edited) The sway bar is between 1.127 and 1.130 inch diameter so that would require the 28 to 30mm or 1 and 1/4 inch lateral lock. I like the idea and I am going to order some for my car. A super easy and lightweight fix . Great find veener79 Alloy high performance lateral locks are designed to maintain Swaybar centralization. 1. Once you have your Swaybar in position and central with links attached,attach the lateral locks next to the mounting bush (leave approx 3-4mm gap).This can be either side of the mounting bush but its best to aim for the most accessible area on the Swaybar. If there is little room to physically tighten the lateral locks, it may be best to mark your Swaybar then remove from vehicle then attach the lateral locks prior to fitment.2. Tighten the lateral lock bolts down evenly and use mild force to secure.Note : Please don’t over tighten.3. After test driving the vehicle, recheck Swaybar position and adjust lateral locks if necessary. Part # - Whiteline KLL130 SwayBar- Lateral Lock, I found them here for $31.32 Free Shipping https://www.bing.com/aclick?ld=d3N4ZdI6-KRyhwsYl7uSbEbjVUCUxTe41iMxl5Vu1svkGtLOjOND8f1gtp3TwkS4S9C3EaKnEUdrUsxsRQuGS9LVm1e2In-ecStQ3rTn5JEzypHuMkElA-yEOE_4j6xx4zaJXsYL5tM9hxuDZt1bhJg3z0EnMyhYr_o25ptEVBdLDr81Lk&u=https%3a%2f%2fwww.carid.com%2fwhiteline%2fsway-bar-alloy-lateral-lock-kit-mpn-kll130.html%3fview%3d178369%26utm_source%3dmicrosoft%26utm_medium%3dcpc%26utm_campaign%3d53463042%26utm_content%3d4181287667 Edited August 12, 2018 by Xtra 4 Quote Link to comment Share on other sites More sharing options...
sfbluenote Posted August 12, 2018 Report Share Posted August 12, 2018 On 8/12/2018 at 12:25 AM, Xtra said: The sway bar is between 1.127 and 1.130 inch diameter so that would require the 28 to 30mm or 1 and 1/4 inch lateral lock. I like the idea and I am going to order some for my car. A super easy and lightweight fix . Great find veener79 Alloy high performance lateral locks are designed to maintain Swaybar centralization.[/size] 1. Once you have your Swaybar in position and central with links attached, attach the lateral locks next to the mounting bush (leave approx 3-4mm gap). This can be either side of the mounting bush but its best to aim for the most accessible area on the Swaybar. If there is little room to physically tighten the lateral locks, it may be best to mark your Swaybar then remove from vehicle then attach the lateral locks prior to fitment. 2. Tighten the lateral lock bolts down evenly and use mild force to secure. Great Post Extra...Thanks for the post and Link. Note : Please don’t over tighten. 3. After test driving the vehicle, recheck Swaybar position and adjust lateral locks if necessary.[/size] Part # - Whiteline KLL130 KLL130.jpg KLL130-3.jpg SwayBar- Lateral Lock, I found them here for $31.32 Free Shipping https://www.bing.com/aclick?ld=d3N4ZdI6-KRyhwsYl7uSbEbjVUCUxTe41iMxl5Vu1svkGtLOjOND8f1gtp3TwkS4S9C3EaKnEUdrUsxsRQuGS9LVm1e2In-ecStQ3rTn5JEzypHuMkElA-yEOE_4j6xx4zaJXsYL5tM9hxuDZt1bhJg3z0EnMyhYr_o25ptEVBdLDr81Lk&u=https%3a%2f%2fwww.carid.com%2fwhiteline%2fsway-bar-alloy-lateral-lock-kit-mpn-kll130.html%3fview%3d178369%26utm_source%3dmicrosoft%26utm_medium%3dcpc%26utm_campaign%3d53463042%26utm_content%3d4181287667 Quote Link to comment Share on other sites More sharing options...
sfbluenote Posted August 12, 2018 Report Share Posted August 12, 2018 The above post from me should have said: Thanks for the info on the lateral locks Extra. Much appreciated... 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 12, 2018 Report Share Posted August 12, 2018 On 8/12/2018 at 12:25 AM, Xtra said: The sway bar is between 1.127 and 1.130 inch diameter so that would require the 28 to 30mm or 1 and 1/4 inch lateral lock. I like the idea and I am going to order some for my car. A super easy and lightweight fix . Great find veener79 Alloy high performance lateral locks are designed to maintain Swaybar centralization. 1. Once you have your Swaybar in position and central with links attached, attach the lateral locks next to the mounting bush (leave approx 3-4mm gap). This can be either side of the mounting bush but its best to aim for the most accessible area on the Swaybar. If there is little room to physically tighten the lateral locks, it may be best to mark your Swaybar then remove from vehicle then attach the lateral locks prior to fitment. 2. Tighten the lateral lock bolts down evenly and use mild force to secure. Note : Please don’t over tighten. 3. After test driving the vehicle, recheck Swaybar position and adjust lateral locks if necessary. Part # - Whiteline KLL130 KLL130.jpg KLL130-3.jpg SwayBar- Lateral Lock, I found them here for $31.32 Free Shipping https://www.bing.com/aclick?ld=d3N4ZdI6-KRyhwsYl7uSbEbjVUCUxTe41iMxl5Vu1svkGtLOjOND8f1gtp3TwkS4S9C3EaKnEUdrUsxsRQuGS9LVm1e2In-ecStQ3rTn5JEzypHuMkElA-yEOE_4j6xx4zaJXsYL5tM9hxuDZt1bhJg3z0EnMyhYr_o25ptEVBdLDr81Lk&u=https%3a%2f%2fwww.carid.com%2fwhiteline%2fsway-bar-alloy-lateral-lock-kit-mpn-kll130.html%3fview%3d178369%26utm_source%3dmicrosoft%26utm_medium%3dcpc%26utm_campaign%3d53463042%26utm_content%3d4181287667 Thanks for the heads up! I'll order them after brunch! Quote Link to comment Share on other sites More sharing options...
Denny Gaughan Posted August 12, 2018 Report Share Posted August 12, 2018 That bad, the suspension will bind if you have it on jacks like it says in the directions, you can totally remove it by just laying on your garage floor like i did. The only hard thing about it is breaking the bolts in the first place. All my bracket bolts seemed to be way over tightened. Also when you remove the end links, i used a t40 or so torx wrench to hold the endlink bolts on the end otherwise theyll just spin with the nut as you remove it. On 8/10/2018 at 6:17 PM, roots57 said: Received my bar this morning, just in time to get it installed this weekend! Any tips on a smooth install? On paper, removing the OEM bar and installing the new one is as straightforward as it gets. But, should I put the rear of the car up on jack stands for more room to work, then put my floor jack under the rear diff and jack it up to about normal ride height? I'm thinking this would take any potential preloading off the links. Would this be the easiest approach? 2 Quote Link to comment Share on other sites More sharing options...
Xtra Posted August 12, 2018 Report Share Posted August 12, 2018 Thanks everyone, but I must add this disclaimer that as yet no one has installed these lateral locks and I am looking forward to feedback on that. I do not anticipate any problems. Quote Link to comment Share on other sites More sharing options...
roots57 Posted August 13, 2018 Report Share Posted August 13, 2018 I actually held off on putting mine in yesterday because I noticed this. The links are pretty damn close to the electronic parking brake mechanism and I didn't want to install the new bar without shaft collars to keep it centered. I got mine from McMaster Carr, they're just two-piece hard anodized aluminum shaft collars w/ stainless steel bolts. I paid the same as you guys, $30 for the pair. I'll get my bar installed today or tomorrow. 3 Quote Link to comment Share on other sites More sharing options...
