blownZ71 Posted January 10, 2018 Report Share Posted January 10, 2018 Has anyone upgraded to a 22" wheel with performance tires? Looking to replace the factory 20" Edge wheels with a 22" wheel and curious how much width I can add and what backspacing anyone else might have used. Trying to avoid the factory 21" wheels due to the limited tire selection. Right now I am thinking 22 x 9 with a 265/35/R22, hoping that will fit or even maybe something slightly larger on a suspension with H&R springs. Any insight from anyone on here? Quote Link to comment Share on other sites More sharing options...
roots57 Posted January 10, 2018 Report Share Posted January 10, 2018 (edited) If you want to play it safe, get wheels with the same offset as the factory wheels. 265/35-22" tires have the same outside diameter and width as the factory 265/40-21" set up, so as long as you don't deviate too far from the factory offset, you won't have any clearance issues. I think you might even be able to get away with 275/35's but then you need to be more careful with offset. Edited January 10, 2018 by roots57 Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted January 10, 2018 Report Share Posted January 10, 2018 Has anyone upgraded to a 22" wheel with performance tires? Looking to replace the factory 20" Edge wheels with a 22" wheel and curious how much width I can add and what backspacing anyone else might have used. Trying to avoid the factory 21" wheels due to the limited tire selection. Right now I am thinking 22 x 9 with a 265/35/R22, hoping that will fit or even maybe something slightly larger on a suspension with H&R springs. Any insight from anyone on here? I did put some 22's on my '16 Titanium. :thumbsup:I kept the original 20"s and mounted winter tires on them. See here: http://www.fordedgeforum.com/topic/22344-finally-bought-some-22-wheels-for-my-edge/ Claude. 1 Quote Link to comment Share on other sites More sharing options...
