bronconut Posted January 8, 2018 Report Share Posted January 8, 2018 Sorry if this has been covered many times. i have searched the forum and not found what i am looking for. i have recently purchased a 2008 Edge limited AWD. The dash display shows "Check Park Aid" and will not clear unless i hit the reset button. i have braced the car, engine off, key in on position, and listened to the sensors in the back. from what i can tell all four are sending echo request. i tried this with the engine running i have tried just can not hear. Not sure if this is because of engine exhaust noise and bad hearing or what. either way i am not hearing any alerts inside the car. Thanks, Shane Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 9, 2018 Report Share Posted January 9, 2018 Try disconnecting the negative battery cable for 40 minutes or more then reconnecting. Let's see if that resets the parking aid module. Hopefully easy as that. How old is the battery in your Edge? I would check not only voltage with everything off, but CCAs as well, just in case it is causing electrical gremlins. Quote Link to comment Share on other sites More sharing options...
bronconut Posted January 9, 2018 Author Report Share Posted January 9, 2018 it is a two year old battery. it was dead and needed a jump when i bought it... ill try removing positive and see what happens Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 9, 2018 Report Share Posted January 9, 2018 Negative cable Quote Link to comment Share on other sites More sharing options...
akirby Posted January 9, 2018 Report Share Posted January 9, 2018 On 1/9/2018 at 5:20 PM, WWWPerfA_ZN0W said: Negative cable It's really hard to get to. I disconnect the positive terminal but I'm really careful not to let it touch anything. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 10, 2018 Report Share Posted January 10, 2018 1 Quote Link to comment Share on other sites More sharing options...
bronconut Posted January 15, 2018 Author Report Share Posted January 15, 2018 Thanks... i have looked at that vid before. I stuck it up on the lift today and did a check... the sensors are clicking... but still not alerts. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 15, 2018 Report Share Posted January 15, 2018 On 1/15/2018 at 8:35 PM, bronconut said: Thanks... i have looked at that vid before. I stuck it up on the lift today and did a check... the sensors are clicking... but still not alerts. Might be the module. 1 Quote Link to comment Share on other sites More sharing options...
bronconut Posted January 17, 2018 Author Report Share Posted January 17, 2018 On 1/15/2018 at 9:53 PM, macbwt said: Might be the module. thats what i am leaning towards.... thanks. Quote Link to comment Share on other sites More sharing options...
