hilokamper Posted January 4, 2018 Report Share Posted January 4, 2018 Outside of Local Dealer Parts counter, What is a good on-line source to purchase these ? Ford Callout Name: HM1 (Hardware Miscellaneous Pin-Retainer, Trim 9 X 0.6 - 1MM) Quote Link to comment Share on other sites More sharing options...
akirby Posted January 4, 2018 Report Share Posted January 4, 2018 Benny at Levittown Ford. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 4, 2018 Report Share Posted January 4, 2018 eBay is where I ended up getting mine because the space between the 3 discs is similar in the part from the dealer. The one I needed, the top space was about 2x the size of the bottom space. Still a tight fit, and probably not of as high quality, but it has worked so far. I believe this one https://www.ebay.com/itm/20x-Nylon-Front-Door-Panel-Clips-Rivet-Retainer-for-2005-2009-Buick-LaCrosse/401062994865 1 Quote Link to comment Share on other sites More sharing options...
