2016 Sport 2.7 BOV
snmjim
  • 11 months later...
I've recently been doing a fair amount of data acquisition and have found that the boost level produced is fairly inconsistent, and often seems greater at mid to 3/4 throttle, 2nd or third gear, generally peaking around 18psi in these conditions.
However, if I go WOT the peak boost seems to drop to around 12-14. Also at lower throttle openings and lower speeds around town, the desired boost value is often 1-2 psi while actual measured boost is zero.
And the performance felt in that range reflects the lack of desired boost.
Is it possible or likely that the BOVs / diverters are leaking pressure, a loose clamp somewhere, or is this likely to be a tune parameter, or designed function?
