ben senise Posted December 21, 2017 Report Share Posted December 21, 2017 I press on the steering wheel button instead of saying "OK Google" when my phone is plugged into the car and running Android Auto. I was just wondering if there is anyway to direct my speaking to Sync instead. For example, if I want to issue a command like changing the climate control temperature or similar. It's a hassle to press the screen to return to sync and do something and then go back to AA. Quote Link to comment Share on other sites More sharing options...
Burrcold Posted December 21, 2017 Report Share Posted December 21, 2017 Short press and release of the talk button will get you Sync 3, and the longer hold gets you AA/CarPlay. 2 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted December 21, 2017 Report Share Posted December 21, 2017 (edited) Not that I know of. When you switch to Android Auto or Carplay voice control of SYNC is lost until you switch back to SYNC. Edited December 21, 2017 by jmr061 Quote Link to comment Share on other sites More sharing options...
Burrcold Posted December 21, 2017 Report Share Posted December 21, 2017 Not that I know of. When you switch to Android Auto or Carplay voice control of SYNC is lost until you switch back to SYNC.Not correct. Check it out. Press the "speak" button on the steering wheel once (short press) and you access Sync. Hold it down and you access Siri (or Google Assistant). Just double checked it and it works. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted December 22, 2017 Report Share Posted December 22, 2017 Not correct. Check it out. Press the "speak" button on the steering wheel once (short press) and you access Sync. Hold it down and you access Siri (or Google Assistant). Just double checked it and it works. While you have carplay or android auto active? Quote Link to comment Share on other sites More sharing options...
Burrcold Posted December 22, 2017 Report Share Posted December 22, 2017 Yes. I sent a text through iMessage and then changed the temp through Sync, all through voice commands. Test complete. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 22, 2017 Report Share Posted December 22, 2017 Yes. I sent a text through iMessage and then changed the temp through Sync, all through voice commands. Test complete. But that’s not CarPlay. That’s just Hey Siri. 1 Quote Link to comment Share on other sites More sharing options...
Burrcold Posted December 22, 2017 Report Share Posted December 22, 2017 Sorry sorry I read the original post again. My bad. Quote Link to comment Share on other sites More sharing options...
ben senise Posted December 22, 2017 Author Report Share Posted December 22, 2017 But that’s not CarPlay. That’s just Hey Siri. changing the temp is siri? Quote Link to comment Share on other sites More sharing options...
akirby Posted December 22, 2017 Report Share Posted December 22, 2017 changing the temp is siri? No - sending a text message. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 22, 2017 Report Share Posted December 22, 2017 No - sending a text message. Burrcold was describing how to use Hey Siri with an iPhone and use sync 3 voice commands interchangeably. You hit the voice button quickly for sync 3 and you hold it for 3 seconds and it sends the voice commands to Siri instead. But that’s not the same as Android Auto/Apple CarPlay. 1 Quote Link to comment Share on other sites More sharing options...
Burrcold Posted December 22, 2017 Report Share Posted December 22, 2017 Exactly. When you have CarPlay on (iPhone plugged in) the talk button only activates Siri (through CarPlay). You have to do everything through the touchscreen to use Sync 3. 1 Quote Link to comment Share on other sites More sharing options...
