AntDeek Posted December 16, 2017 Report Share Posted December 16, 2017 My manual states WSS-M97B44-D2 and I recently did a coolant change (no flush, just drain and fill) with 2 gallons of Prestone Dex-Cool 50/50. The bottle says it meets WSS-M97B44-D without the 2. Did I use the wrong coolant? Is the D2 a different spec? 2013 Edge 3.5 52k miles. Currently running Castrol Edge 5W20 Extended Performance and an FL500S. I'm an oil nerd and wondering if anyone else is too. Thanks guys! Quote Link to comment Share on other sites More sharing options...
chefduane Posted December 16, 2017 Report Share Posted December 16, 2017 I run Mobil-1 5w20 Extended Performance Full Synth and a Mobil-1 M1-212 Extended Performance filter at 5k intervals, give or take. 5.5qts/5.2L with filter. I've had good luck with Mobil-1 products on other vehicles so I saw no need to change. Coolant is Motorcraft Specialty Green VC-10A2/WSS-M97B55A. Mind you, these are for my '11 AWD Limited. 11.7qts/11.1L. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 16, 2017 Report Share Posted December 16, 2017 (edited) The coolant you used should work fine. It is strange that on the Ford chemicals site, the concentrate is the D spec, the premix is D2 spec. Meh. Not to worry. As far as oil goes, Motorcraft oil is good, just not as easy to get deals on as with aftermarket brands. Ultimately, it is about OCI. SOMEtimes, it's about the filter, can't go wrong with Motorcraft filters. There are certainly better aftermarket filters, as long as they don't cause startup rattle, you're good. Edited December 16, 2017 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
AntDeek Posted December 17, 2017 Author Report Share Posted December 17, 2017 I prefer using extended performance oils as I like the added protection. I always use an FL-500S. Quote Link to comment Share on other sites More sharing options...
chefduane Posted December 17, 2017 Report Share Posted December 17, 2017 Mobil advertises that M1 meets/exceeds the Ford FL-500S spec. I'm sure you couldn't go wrong with either one. Quote Link to comment Share on other sites More sharing options...
dat2109 Posted January 31, 2018 Report Share Posted January 31, 2018 I'm an oil and coolant nerd too. I think you did just fine with both the oil and the coolant. The newest Edge come with Ford's version of the old Dexcool, and all the Dexcool are compatible* I've generally called these OAT coolants Dexclones. Most of the autoparts store green/gold are this type now, they switched quite a while ago to 'extended life' or 5 year 100k mile formulations. The coolant nerds like Peak Global lifetime coolant as the king of the Dexcool / Dexclone coolants. Quote Link to comment Share on other sites More sharing options...
thesavo Posted November 12, 2018 Report Share Posted November 12, 2018 IS all dexcool compatible? The owners guide for Model Year 2013 and 14 calls for WSS-M97B44-D2 not D. I am also looking for clarification. There are ford documents that state you can Use D2 fluid where D is called for. Nothing states that the reverse is true. I found another document that states D2 is pre- diluted and D (proper) is undiluted. My fear was D2/D compatibility was similar to the old Mercon vs Mercon V issue. Where Mercon V could be used in all applications that Mercon (proper) was called for. Source: https://www.fcsdchemicalsandlubricants.com/main/quickref/coolantsEN.pdf http://spautoparts.com/documents/CoolantFAQs.pdf Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 13, 2018 Report Share Posted November 13, 2018 D vs D2 is just concentrate vs premixed 50/50. Not a concern, it is a product number difference rather than an actual spec difference. As you surmised. You have the option which one you want to use. Quote Link to comment Share on other sites More sharing options...
omidsolo Posted January 10, 2021 Report Share Posted January 10, 2021 Hey coolant nerds, please help me ? I don't find Motorcraft Yellow/Orange coolant for my Edge 2013 3.5 So please advise if: Using Motorcraft Gold which is not listed for this car will damage something or what? And ACDelco, is this one better now or I use the same Motorcraft Gold model? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 10, 2021 Report Share Posted January 10, 2021 Dex-cool (the current version) is theoretically compatible with Motorcraft/Ford Orange. Do you have the back label of this jug as well? To see the specifications this coolant is compatible with. Much preferred if you can get Peak, Prestone, Zerex branded universal extended life coolants instead. What do you have available in your country? Full flush recommended regardless of what coolant you go with. Quote Link to comment Share on other sites More sharing options...
DaMiFo Posted January 10, 2021 Report Share Posted January 10, 2021 Motorcraft Gold is NOT compatible with Orange/Yellow coolants. I second the post above - if you change coolants, a full (or as close as you can get) drain & fill (most people agree 3 times with running the engine in between) is recommended. Quote Link to comment Share on other sites More sharing options...
omidsolo Posted January 11, 2021 Report Share Posted January 11, 2021 Hey thanks for the advise, mostly these 2 and local "Made in UAE" green/red ones! So can I use this ACDelco Dex-Cool? Quote Link to comment Share on other sites More sharing options...
niceonept Posted January 11, 2021 Report Share Posted January 11, 2021 Looks like the only difference is that the D2 is pre-diluted. Useful guide to Ford-Motorcraft coolants here: https://parts.ford.com/content/dam/ford-parts/resources/motorcraftpdf/Coolants_Brochure.pdf Quote Link to comment Share on other sites More sharing options...
omidsolo Posted January 11, 2021 Report Share Posted January 11, 2021 On 1/11/2021 at 10:27 AM, niceonept said: Looks like the only difference is that the D2 is pre-diluted. Useful guide to Ford-Motorcraft coolants here: https://parts.ford.com/content/dam/ford-parts/resources/motorcraftpdf/Coolants_Brochure.pdf Expand Thanks, so does it mean the above ACDelco is compatible? Quote Link to comment Share on other sites More sharing options...
niceonept Posted January 11, 2021 Report Share Posted January 11, 2021 On 1/11/2021 at 1:38 PM, omidsolo said: Thanks, so does it mean the above ACDelco is compatible? Expand I would have thought so, if it says it is WSS-M97B44-D. It would just need diluting with distilled water. Quote Link to comment Share on other sites More sharing options...
omidsolo Posted January 11, 2021 Report Share Posted January 11, 2021 (edited) On 1/11/2021 at 3:46 PM, niceonept said: I would have thought so, if it says it is WSS-M97B44-D. It would just need diluting with distilled water. Expand Thanks, this model is pre-mixed so no need to add water, here's the product: Part # 88862645 https://www.amazon.ae/ACDelco-DEX-COOL-Extended-Anti-Freeze-Pre-Diluted/dp/B07Q23CX84 Edited January 11, 2021 by omidsolo Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 12, 2021 Report Share Posted January 12, 2021 yes you can use it in the Edge. but you must flush the existing coolant in the process. regardless of how close the formulations are, we don't want to roll the dice by mixing them. Quote Link to comment Share on other sites More sharing options...
niceonept Posted January 12, 2021 Report Share Posted January 12, 2021 On 1/11/2021 at 11:22 PM, omidsolo said: Thanks, this model is pre-mixed so no need to add water, here's the product: Part # 88862645 https://www.amazon.ae/ACDelco-DEX-COOL-Extended-Anti-Freeze-Pre-Diluted/dp/B07Q23CX84 Expand I can't see anywhere on there that states it is equivalent to either WSS-M97B44-D or WSS-M97B44-D2. I wouldn't use it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 12, 2021 Report Share Posted January 12, 2021 FWIW, my local dealer told me they no longer stock any coolant other than the latest yellow. . As my 09 came with gold, they did a full flush (he told me the procedure, seemed more than a simple rinse, used two different chemicals plus water flush). Had to be certain they got all of the old coolant out as it would cause a goo (my description) to form inside the system and clog the heater core. Anyway, he said that Ford wants dealers to only carry the latest and switch over all older cars to New. Personally I'd stick to Motorcraft. No advantage to using any other brand. 2 Quote Link to comment Share on other sites More sharing options...
omidsolo Posted January 15, 2021 Report Share Posted January 15, 2021 Hey, one question, in Ford manual I didn't see any Ford that needs Motorcraft GOLD Coolant! Anyone knows which car and build is Gold made for? Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 15, 2021 Report Share Posted January 15, 2021 On 1/15/2021 at 12:31 PM, omidsolo said: Hey, one question, in Ford manual I didn't see any Ford that needs Motorcraft GOLD Coolant! Anyone knows which car and build is Gold made for? Expand The Gold is superseded / obsolete. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 15, 2021 Report Share Posted January 15, 2021 On 1/15/2021 at 12:31 PM, omidsolo said: Anyone knows which car and build is Gold made for? Expand Gold was used starting in 2007 cars up through those built on or before 01/19/2009. On that date Ford/Lincoln switched to Dark Green. If you have gold and are thinking of switching to a newer coolant, there is a specific flush procedure that MUST BE FOLLOWED. And one part of the cooling system must be changed if your engine build date was built on or before 04/01/2008. The part is the water pump inlet tube. The old style is painted on the inside and the flushing chemicals will dissolve the paint, contaminating the cooling system and exposing bare steel to the coolant. 1 Quote Link to comment Share on other sites More sharing options...
