enigma-2 Posted December 15, 2017 Report Share Posted December 15, 2017 Noticed that my washer was no longer working on the drivers side, and the passengers side was weak. Quick investigation revealed that the nozzle broke under the hood insulation blanket. The Ford & MKX nozzles make a sharp right-hand turn just under the hood and the hose puts a lot of tension on this connection. Figured that if one was bad, the other would follow in short order. Stopped by local Ford dealer and got clipped for $24 for two of them. Recommend if you are replacing yours, go with Dorman off Amazon. Anyway, you pull the insulation blanket with a trim tool (taking care not to lose one like a certain idiot we won't mention did) and the blanket slips right off the two metal clips. The old nozzles remove by pinching the prongs on the underside and they pop right off. When I went to remove the passenger side it easily broke off as I touched it. (These nozzles are cheap plastic and age quickly do to engine heat). In both cases the part of the nozzles that slip into the hose remained in the hose. The new nozzles easily slip into the holes in the hood and lock into place. Went to remover the plastic stubs in the end of the hose and they crumbled. Each little bit had to be scraped/dug out with a small screwdriver. (Any ltitle bit left behind will clog the new nozzle). After digging and digging, I used a Q-tip and did my best to clean out the remainder (which was now powder). Finally I turned on the washer and used the stream to wash out any remaining particles. The hoses push on easily (the drivers side was a stretch). Blanket slips back in place, trim clips push back in easily (minus one) and done. 5 Quote Link to comment Share on other sites More sharing options...
evh Posted December 16, 2017 Report Share Posted December 16, 2017 Very common. My 2009 did the same thing. Nice write-up. 1 Quote Link to comment Share on other sites More sharing options...
pintokid Posted December 16, 2017 Report Share Posted December 16, 2017 Thanks for the details. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 16, 2017 Report Share Posted December 16, 2017 On the topic of washer nozzles, any experience with the Dorman replacement? Is the spray pattern different from oem? I just hate how the oem spray high & hence don't get enough washer fluid at the bottom of the windshield at driver's side hence wipers doesn't clean good unless a lot of water is sprayed. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 16, 2017 Author Report Share Posted December 16, 2017 I was only recommending Dorman because of price. I was assuming that they're the same quality as OEM. Spray pattern of new nozzles appear to be ok, perhaps more on upper area vs. lower. I'll have to look today whole we're out shoping. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 18, 2017 Author Report Share Posted December 18, 2017 Follow up: the pattern is "V" shaped, full upper and lower part of the windshield (think oval). If yours us only on the top it sounds like it's partially clogged. For $12 why not just pop a new one in? Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 18, 2017 Report Share Posted December 18, 2017 I already got a new OEM nozzle. The spray pattern is good, only it doesn't get enough fluid at the bottom driver side of the windshield. I also noticed the part number is different, 2007-10 & 2011-14, though they look the same. That might explain the different experiences. 2011: https://www.tascaparts.com/oem-parts/ford-washer-nozzle-bt4z17603a 2010: https://www.tascaparts.com/oem-parts/ford-windshield-hood-nozzle-7t4z17603a 1 Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted December 18, 2017 Report Share Posted December 18, 2017 my 2007 did it also. EBay for original ford parts. I have had some bad experience with aftermarket parts. I wonder what the dealership would charge for this very complicated job lol 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted December 18, 2017 Report Share Posted December 18, 2017 They wanted $100 to change the cabin air filter & engine air filter in my mom's 2012 fusion. Both can be had for under $25 with Motorcraft parts on Amazon. $75 to install 2 components that take less than 5 minutes to change out total. Can't remember if it requires tools to pop open the cabin air filter or not, but i don't think so. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 18, 2017 Author Report Share Posted December 18, 2017 my 2007 did it also. EBay for original ford parts. I have had some bad experience with aftermarket parts. I wonder what the dealership would charge for this very complicated job lolI was quoted 1/2 hour + parts. (Guess they know that it will involve scrapping and digging the old plastic out.) 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 7, 2019 Report Share Posted October 7, 2019 My 2008 did this as well. However, it wasn't the nozzle. I had to replace the plastic T joints under the insulation blanket. One practically disintegrated in my hand. Mine could be attributed to extreme heat. Quote Link to comment Share on other sites More sharing options...
