Eflood Posted December 7, 2017 Report Share Posted December 7, 2017 Hello all new here looking for some help on my 2011 Edge. Fuel pump went out and I am hoping there is some sort of access from inside instead of having to drop the tank? The pump itself seems to be a very illusive part that is either completely over priced and a special order no one carries. Hopefully I can get a solid answer here. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 7, 2017 Report Share Posted December 7, 2017 (edited) Welcome! Sorry, dropping the fuel tank is needed to replace the fuel pump At least since 2010MY this has been the case. Is your Edge AWD or FWD? Different fuel pumps. http://www.rockauto.com/en/catalog/ford,2011,edge,3.5l+v6,1446671,fuel+&+air,fuel+pump+&+housing+assembly,10147 MOTORCRAFT PFS581 {#BT4Z9H307C} Sender Assembly AWD$143.79 MOTORCRAFT PFS1033 {#DT4Z9H307A} Sender Assembly FWD$151.79 Edited December 7, 2017 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
