engine swap ford edge
colorado
ok, decided to change my engine because my phaser where damage and the engine got 334000 km on it. the problem is that i notice that the engine they sold me is from a ford taurus 2010, look the same but no oil cooler on engine and wiring is different. they told me it the same thing. so if i remove my original wiring and put it on the engine without the oil cooler and just bypass the 2 oil cooler hose. would that work. right now both engine are on the floor. hope it would work. thanks for any help
Yes, it should work if you transfer over the wiring, and bypass the oil cooler. You can get the appropriate non-cooler adapter for your Edge if you so wish. Also confirm that there is only 1 VCT solenoid per bank, indicating it is a VCT and not a TiVCT engine.
How many miles on the "new" engine? You might consider changing the plugs, PCV valve at a minimum while you have it on the floor/stand. With enough mileage, I would replace the water pump and possibly the timing components before installation.
for the oil cooler, the other engine has a 3 bolt attachment instead of a 1 bolt like my edge. also, my engine is in the car, when i came to installed the alternator, it look crooked when i look at the engine, tried many thing to make it straight but no luck, the belt look a little bit off too, that alternator only goes in one way, no play for adjustment. any idea what going on. thank guys, appreciate the help.
