Will Fitting H&R Springs on my '17 Sport void warranty?
Depends...If you're seat stops moving forward/backwards, they can't blame the H&R springs.
Your shock fails and starts leaking, they will likely say the springs caused the premature failure and tell you you have to pay up.
There are many folks running the springs. They are not an aggressive drop but you will likely be shortening the life of the shocks/struts by a bit.
I much prefer the ride of the springs and am willing to pay if the struts or shocks fail sooner rather than later.
This is what the warranty says:
Damage Caused by Alteration or Modification The New Vehicle Limited Warranty does not cover any damage caused by:
alterations or modifications of the vehicle, including the body, chassis, electronics or their components, after the vehicle leaves the control of Ford Motor Company
tampering with the vehicle, tampering with the emissions systems or with the other parts that affect these systems (for example, but not limited to exhaust and intake systems) the installation or use of a non-Ford Motor Company part or software (other than a certified emissions part or software) or any part or software (Ford or non-Ford) designed for off-road use only installed after the vehicle leaves the control of Ford Motor Company, if the installed part fails or causes a Ford part to fail. Examples include, but are not limited to lift kits, oversized tires, roll bars, cellular phones, alarm systems, automatic starting systems and performance-enhancing powertrain components or software and performance chips.
